Cleaning gunk from the crank case?
Old 08-03-2014, 10:56 AM
1'stonraceday's Avatar
1'stonraceday
1'stonraceday is offline
Somewhat unrelated to anything Ford . . . but I know this site has some mechanical geniuses . . . and I need help.
It's a Briggs motor. I use it with a water pump. Apparently the seal went out and there is water in the oil/crank case. The oil's a real pretty off-white!)
What can I put in there to clean all that out? I've heard diesel fuel works very well. Of coarse I wouldn't be starting it, just rotating the crank with starter rope and spark plug removed.
Old 08-03-2014, 10:48 PM
jimbbski's Avatar
jimbbski
jimbbski is offline
Diesel Fuel, Kerosene, or Gasoline will work but the first two are much safer to use. Gasoline vapors can ignite easily with nasty results.
Old 08-13-2014, 04:08 PM
xlt4wd90's Avatar
xlt4wd90
xlt4wd90 is online now
I've found that nothing beats getting in there with brush or scrapers. But only do that if you're overhauling the engine already.
I opened up a 4 liter v6 in an Aerostar van I bought second hand and found an amazing amount of solid crud in it. It had a one-piece intake manifold gasket, with a wide section that spanned the lifter valley. It looked like someone dumped a cup of cat litter on it. There was a similar collection of crud in the oil pan. No amount of engine flushing would have gotten that stuff out.
fladoodle
29
06-18-2015 09:05 PM
1'stonraceday
General Automotive Discussion
08-04-2014 01:42 PM
Oakroadjoe
02-14-2007 10:33 PM
Trlhound
08-11-2006 10:58 PM
janedoe058
Oil & Lubrication
07-02-2006 10:24 AM
Quick Reply: Cleaning gunk from the crank case?
