manual sunroof conversion? - Ford Truck Enthusiasts Forums
Old 05-17-2014, 02:50 PM
davidjurss's Avatar
davidjurss davidjurss is offline
davidjurss is starting off with a positive reputation.
Has anyone converted their power sunroof to a manual sunroof, or even sealed theirs up completely? Mine is broken and leaking, and the stealership wants too much to fix it. I've looked at manual kits, as well as sealing it up completely since I never use it. Has anyone else tried either of these options?
Old 05-17-2014, 03:20 PM
j mcm j mcm is offline
j mcm is starting off with a positive reputation.
Depending on what is broken on yours, would probably be easier and cheaper to fix it yourself. The most common failure are the small parts that keep it moving in the slide. You can get parts at sunroofdr.com. Probably about $110 for the slide parts. They also provide good instruction for the repair. The biggest part of the repair job is dropping the headliner and associated parts. If you decide to go this way, I can provide some more detail.
Joe
Old 05-17-2014, 03:48 PM
davidjurss's Avatar
I've been giving the repair kit a lot of thought, but I'm never home long enough to fix it myself. Only home for a total of 4 days a month and I'm always trying to catch up in things that didn't get fixed from the last time I was home. I've never used it anyway, so blocking it off wouldn't bother me, just not sure what the most effective way to do that would be.
Old 05-20-2014, 02:00 PM
Raider50's Avatar
Raider50 Raider50 is offline
Raider50 is starting off with a positive reputation.
Let me know what you figure out. I am planning on repainting my truck by this fall and was thinking about tearing the guts out of the sunroof and getting a non sunroof headliner and welding in a piece of sheet metal. The only thing that has broken on my truck after the better part of 190k supercharged ruff riding miles are the options. Next truck im getting is going to be an XL.
Old 05-20-2014, 02:26 PM
davidjurss's Avatar
I think I'm just gonna seal it shut with some silicon and be done with it. It's a King Ranch and I'm tired of my Castano leather being soaked after a hard rain. I don't have time to mess with it, so I'm sealing it. It's the only persistent problem I've had with it.
Old 05-20-2014, 02:45 PM
Raider50's Avatar
Mine doesn't let in water just howls while driving, if that fixes it up nice report back and ill probably do that as a temporary fix.
Old 05-25-2014, 08:03 PM
davidjurss's Avatar
Bought 3 tubes of Permatex black silicon sealant and ran a thick bead around the seal. Used my index finger to spread it out and let it cure. So far it's holding up ok. 45 minutes and a black finger later, it's sealed and I don't hear any wind through it anymore, and I'm hoping it doesn't leak anymore. I'll find out when it rains again.
Sunroof leak fix! $10 Welder7018 1997-2006 Expedition & Navigator 6 11-11-2015 05:26 PM
Sunroof Switch Unresponsive Big Smoke 2007 - 2014 Expedition & Navigator 0 10-19-2015 09:44 AM
Sunroof issue.. Dealer screwed it up, and won't fix it! JRD761 1999 to 2016 Super Duty 6 07-17-2015 12:09 PM
Sunroof leak question acf6 1999 to 2016 Super Duty 8 02-23-2015 08:14 PM
Sunroof Dilemma Squad Cab 1999 to 2016 Super Duty 6 12-02-2014 06:59 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
