Wiring Diagram for a electronic ignition - Ford Truck Enthusiasts Forums
Old 07-06-2003, 11:16 PM
tracman tracman is offline
tracman is starting off with a positive reputation.
My uncle just bought a 69 f100. He is putting a 302 from a 1980 Thunderbird in it. He wasn to use the electronic ignition, and wants me to wire it up for him.
Do you all have any IDeas where I can get the Diagram I need?
Thank you.
Old 07-07-2003, 12:11 AM
sparky's Avatar
sparky sparky is offline
sparky is starting off with a positive reputation.
Old 07-07-2003, 01:10 AM
Hey ya Sparky. Thank you. That should work great.
Old 07-13-2003, 10:14 PM
frog frog is offline
frog is starting off with a positive reputation.
When I bought the 72 for my son, the previous owner had wired in a later model duraspark setup. when I installed a MSD ignition, I realized I did not need the duraspark. So I ripped out the bad installation of the duraspark wiring and installed the MSD with all new wiring and sanitary installation. Looks and runs great.
Good luck.
Old 07-14-2003, 09:09 AM
I got this one wired up and is working great. Thanks for the diagram. One other problem now though. Will post that in a sec.
Need A Wiring Diagram: Ignition Noise Capacitor wavetrain75 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 12-21-2016 01:23 PM
Tachometer Install connection to Electronic Ignition BGF100 1973 - 1979 F-100 & Larger F-Series Trucks 10 10-15-2016 10:58 AM
Looking for help on wiring electronic distributor Kyra Nguyen 1967 - 1972 F-100 & Larger F-Series Trucks 7 07-09-2012 12:08 PM
1980 F150 electronic ignition module wiring diagram needed Street Electrical Systems/Wiring 2 05-20-2004 10:28 PM
MSD 6A ignition on 84 F-250/460 BLaCkSiLo Electrical Systems/Wiring 5 01-28-2004 04:04 AM
Tags
1972, 370, 460, cid, connecting, diagram, distributor, elect, electronic, f250, ford, ign, ignition, msd, tachometer, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
