Touchy Steering
Old 05-16-2014, 08:01 AM
CLARK3234's Avatar
CLARK3234
CLARK3234 is offline
Touchy Steering
I have 2001 X V10 4WD. It has a really touchy steering to it. you barely move the wheel and you are moving. I have had a Les Schwab tires check out the suspension and alignment and everything checks out fine. I was towing our 31 foot trailer with a equalizer hitch and I was fighting it the entire way. Is there anything can do to improve the steering?
Old 05-16-2014, 09:14 AM
BassFantasizer's Avatar
BassFantasizer
BassFantasizer is offline
Received 4,678 Likes on 2,606 Posts
An Excursion where the steering is too tight? Now that's an oddity!
You might back the tension adjustment on the steering box back about 1/4 turn. It sounds like it's been over tightened.
Old 05-16-2014, 10:59 AM
EXv10's Avatar
EXv10
EXv10 is offline
I would check the alignment by someone else, positive toe out will cause that. The steering box can't be "too good", my box has zero play and it tracks like a freight train.
Old 05-16-2014, 11:03 AM
EXv10's Avatar
EXv10
EXv10 is offline
Sorry, gotta say you are wrong here. It's not a "tension adjustment" and the goal is to get them tight to the point of binding.
Old 05-16-2014, 11:33 AM
DavenTn's Avatar
DavenTn
DavenTn is offline
Clark... make sure your explaining the issue as accurate as possible. Let me ask, does "touchy" mean the vehicle wanders and your constantly correcting? Have you checked your tire pressure? Do you know the tongue weight? What size and type of tires? Does the vehicle seem to have touchy steering when your not towing? Is this your first evolution for towing?
Try this... start the vehicle, open the hood, find the steering shaft where it enters the steering box. Put your eyes on the pitman arm (the part that connects to the steering linkage from the steering box). Have a second person move the steering wheel slightly to observe for play. In a perfect world = zero play... however some is expected on older parts, but too much means adjust or replace.
Worn out steering boxes/wandering vehicles are chronic complaints.
Old 05-16-2014, 03:03 PM
EXv10's Avatar
EXv10
EXv10 is offline
What about those tires? size, rating, age, brand, tread, etc?
v10Excursion04
03-16-2014 12:36 PM
Fordsdad
11-21-2013 06:52 AM
midsouth
04-06-2012 07:01 PM
jsalty
11-17-2009 06:40 PM
Quick Reply: Touchy Steering
