390 Crankshaft - Page 7 - Ford Truck Enthusiasts Forums
390 Crankshaft
  #91
Old 07-21-2014, 06:03 PM
hickory1991 hickory1991 is online now
hickory1991 is gaining momentum as a positive member of FTE.
Dimmer switch.
  #92
Old 07-21-2014, 06:11 PM
mckoloum mckoloum is offline
mckoloum is starting off with a positive reputation.
Thanks Hickory,
I would never thought they will install a dimmer switch at this place!
So this is just for the headlight right?
  #93
Old 07-21-2014, 06:20 PM
You got it. Back in the day most cars and trucks had them on the floor.
  #94
Old 07-22-2014, 09:37 AM
redroad's Avatar
redroad redroad is offline
redroad has a good reputation on FTE.redroad has a good reputation on FTE.
Quote:
Hi all,
So I have been busy trying to set up my new air compressor. I started with PVC pipe and realize the hard way that it was a mistake, A fitting explode when I open the valve with 155 psi in the tank!...
Thankfully the debris didn't touch me. I learn also that black iron pipe should be use for air tool delivery, insurance could refuse to insure you if you use PVC or even copper...
Yikes ! .. That will get the heart pumping .. Nice compressor BTW (by the way) ..
It looks like you've already been putting it to good use
When I was stationed in Germany after Viet Nam I had a 60's Mercedes that had a windshield wiper switch on the floor that would make one pass with the wipers every time your foot touched it .. Pre-intermittent wiper switch
Keep up the good work
  #95
Old 07-22-2014, 12:22 PM
John I can't imagine driving that Mercedes here in Florida if I had to press the switch all the time, specially with all that rain we have lately, better have to learn how to play drum, that will help!
Well I also learn I should keep the helmet when welding, closing my eyes was not enough, I feel like sunburn all over my face!...I knew it could be bad but not that fast! live and learn..
Thanks
  #96
Old 07-27-2014, 01:32 PM
Here I installed my Home Depot version of the Dynamat, much cheaper $20 for a 15Ft roll, and it does absorb the vibration.
I removed the steering column, there is so much play, does anyboby know if there is any way to rebuild those?
  #97
Old 07-27-2014, 02:07 PM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is offline
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
Quote:
Looks good .
Where is the play coming from? It's rare that the column itself has play. Usually the play is in the rag joint. steering box or suspension.
The columns can be rebuilt, its just usually not necessary.
The most common area for play in the column is the lower bearing. OEM pieces are still available but Bronco Graveyard has a neat lower bearing kit that replaces the plastic support with a real bearing.
Column Bearing, Lower
  #98
Old 07-28-2014, 06:37 AM
ford_pickup ford_pickup is offline
ford_pickup is starting off with a positive reputation.
what is that mat called at Home Depot? if you don't mind me asking
  #99
Old 07-28-2014, 07:49 AM
No Problem here is the link Ford_pickup:
Frost King E/O 12 in. x 15 ft. Self-Stick Foam/Foil Duct Insulation-FV516 at The Home Depot
If you look in the comment/review section you will see some people use it for car.
  #100
Old 07-28-2014, 07:57 AM
Mike,
Where the rag joint attach on the steering column, this is where I have a little play in any direction. I can't see any accessible bearing, I mean nothing like the pic from Bronco Graveyard.
I am going to take a picture, maybe the steering column that I have is missing soimething!
  #101
Old 07-28-2014, 08:15 AM
mikeo0o0o0's Avatar
Mike, maybe the steering column that I have is missing soimething!
You're probably not missing anything.
Some columns have a lower bearing, but a lot of columns have just a plastic bushing that pops into the end of the column. Even new, these bushings have a lot of slop in them. I guess Ford figured the rag joint would hold everything in alignment.
The Bronco Graveyard bearing is an aftermarket unit that works really well and takes all the slop out. It doesn't resemble anything that was NOS.
  #102
Old 07-28-2014, 01:24 PM
Here is the lower part of my steering, there is a black plastic bushing who was in the outer tube, but no sign of lower bearing!!!...
It looks like I am going to replace the steering one day by an Ididit, but until I have the money is there anyway to fix it?
Mike do you think the lower bearing from Bronco Graveyard will fit because it say it will fit Ford F series from 1976-79?
I don't mind if I have to weld it.
  #103
Old 07-28-2014, 02:18 PM
mikeo0o0o0's Avatar
Your column has my sympathy! It looks like it's had a hard life.
Actually that plastic piece is the 'bearing'. Your column isn't missing anything.
As abused as that column is, I don't know if the JBG bearing would fit, the ends pretty beat up.
In this case, I would just get a replacement plastic piece and let it go at that. I know LMC has them. #47-0797 Lower column bushing $4.95.
  #104
Old 08-03-2014, 08:34 AM
Good Morning Everybody!
Happy Sunday,
I find a set of connecting rods, I think this is a really good deal if nobody else bid on it.
But since I am the only one bidding, is there something wrong I didn't see???
Does the length of the rod is too short??
I did the math and the difference with the original is only 0.3mm or 0.0118 of an Inch.
http://www.ebay.com/itm/191266659092?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Thanks guys
  #105
Old 08-03-2014, 09:18 AM
mikeo0o0o0's Avatar
Those rods will work. There are only two rod lengths for the FE series. The 360 uses the long rod (6.54") and the 390 uses the short rod (6.48").
390 high performance truck cam help!!!! 1976f150dude FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 23 10-20-2015 02:46 PM
Converting FT Block to FE Setup ScallyWaggler 1973 - 1979 F-100 & Larger F-Series Trucks 0 05-16-2015 06:21 PM
best cam for 390 FE???? 1976f150dude 1973 - 1979 F-100 & Larger F-Series Trucks 20 11-19-2014 05:03 AM
390 Crankshaft HillBillyBuddha 1961 - 1966 F-100 & Larger F-Series Trucks 19 01-07-2013 09:41 PM
Casting numbers 71LTD390 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 3 03-07-2004 05:36 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
