390 Crankshaft
#46
Redroad the head who were for sale on Ebay are ended but the seller put an other set, and he said the head were resurfaced and 0.020 was taking off, is it a big deal?
http://www.ebay.com/itm/Ford-Heads-FE-390-428-GT-C8AE-H-Castings-Date-Codes-0-K-20-0-K-21/191191023723?_trksid=p2047675.c100012.m1985&_trkparms=aid%3D444000%26algo%3DSOI.DEFAULT%26ao%3D1%26asc%3D20131230161411%26meid%3D7181158013731140724%26pid%3D100012%26prg%3D20131230161411%26rk%3D2%26rkt%3D10%26sd%3D191189063008
#47
#49
This seems to be really interesting, I also heard people was restricting the oil passage to the heads by tapping the hole and putting a jet from a carb! I guess I will have to do those mods for the oil passages!
Also I order those heads, I think I had a good deal $645 including shipping, 2.09 and 1.6 with SS valve and new spring.
Next will be get the crankshaft and connecting rod with 6.49 lenght.
#50
#51
#52
Part #9228 - 390/428 engine, 2" primaries, 3 1/2" collectors, fenderwell exit http://www.maddogheaders.net/ these are 4wd headers
#53
Hi Redroad,
What about those headers? Is it what you suggest I should use!...
They are for 4wd, do I need a lift to install them?
I am not there yet!
Today I had a good day. I took apart grille, fenders, inner fenders and start to clean the frame with wire brush and a lot of degreaser... I am going to use the same spray can as HIO used.
I am not there yet!
#54
Hi mckoloum .. I think these are what the F-100 guys are using these days .. Your heads are set up to use either exhaust flange so your good there
The Sanderson FF427 header set is designed to fit 1953-Up Ford F100 pickups using the Ford 332-428 FE engines.
#55
I forgot Stan also makes a good header for your truck Headers for Ford, Mustang, Pinto, Bronco, Cougar, Ranger, exhaust parts for home built do it yourself automotive headers.
#56
Well I guess I will have to get rid of the existing exhaust, I think the pipe is like 2''...
This is how it looks now
<a href="http://s1072.photobucket.com/user/laurentlesage/media/DSC_0369_zpsc517269e.jpg.html" target="_blank"><img src="http://i1072.photobucket.com/albums/w364/laurentlesage/DSC_0369_zpsc517269e.jpg" border="0" alt=" photo DSC_0369_zpsc517269e.jpg"/></a>
<a href="http://s1072.photobucket.com/user/laurentlesage/media/DSC_0370_zps0ba61555.jpg.html" target="_blank"><img src="http://i1072.photobucket.com/albums/w364/laurentlesage/DSC_0370_zps0ba61555.jpg" border="0" alt=" photo DSC_0370_zps0ba61555.jpg"/></a>
<a href="http://s1072.photobucket.com/user/laurentlesage/media/DSC_0371_zpscbe3198b.jpg.html" target="_blank"><img src="http://i1072.photobucket.com/albums/w364/laurentlesage/DSC_0371_zpscbe3198b.jpg" border="0" alt=" photo DSC_0371_zpscbe3198b.jpg"/></a>
And here is the garage, Thankfully the wife is ok with that! I let her foster a doggy who need some help, so she is happy with that.
<a href="http://s1072.photobucket.com/user/laurentlesage/media/DSC_0372_zpse85233c7.jpg.html" target="_blank"><img src="http://i1072.photobucket.com/albums/w364/laurentlesage/DSC_0372_zpse85233c7.jpg" border="0" alt=" photo DSC_0372_zpse85233c7.jpg"/></a>
#57
#58
#59
No I never heard about emissions in Florida! Should I get rid of the canister? And what about the line coming from the gas tank for the vapor, could I cut the line and put like a small crankcase filter?
Yes I am sure my wife will be interested, she already say talking to the truck :"The beast who steal my husband..."
#60
http://www.ebay.com/itm/Ford-FE-Headers-352-360-390-428-/121347672672?pt=Vintage_Car_Truck_Parts_Accessories&hash=item1c40e28a60 they might fit ..
I would take the canister out only to clean the frame and paint .. cap the lines for now and if it is needed you can add back and use a carb like the Ford/Holley 4180c (600 cfm) which can be set up for the canister or not .. I can give you a lot of info on this carb .. I rebuilt one for my 460 and 390 and absolutely love them .. They can be gotten for $75 and they already have provisions for the ford auto (C-6) kickdown linkage .. They require some modifications but can be made to be great carbs for around $100
