flywheel torque - Ford Truck Enthusiasts Forums
flywheel torque
Old 05-15-2014, 05:23 PM
brokeasajoke brokeasajoke is offline
brokeasajoke is starting off with a positive reputation.
flywheel torque
Changing clutch and had the flywheel resurfaced on a 99 7.3. Whats the best way to hold the motor while torquing the flywheel bolts (89ftlb is what ive come up with), or just loctite them and run them in with impact? Thanks
Old 05-15-2014, 07:07 PM
Dan V Dan V is online now
Dan V has a very good reputation on FTE.Dan V has a very good reputation on FTE.Dan V has a very good reputation on FTE.Dan V has a very good reputation on FTE.
A helper.....
Old 05-15-2014, 08:25 PM
mueckster's Avatar
mueckster mueckster is offline
aka Redneck Wrencher
mueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputation
You could bolt a strap across a pressure plate bolt hole to a bell housing bolt hole, but a couple of bolts in the pressure plate holes and a long bar would also do the trick.
Old 05-15-2014, 08:30 PM
Thats a good idea thanks. Anyone by chance know the thread size on pressure plate bolts? Could grab a few longer bolts while at work tonight.
Old 05-15-2014, 08:35 PM
mueckster's Avatar
If memory serves me correctly (it has been a few years since I helped do one), they are 5/16"-18 coarse thread.
Old 05-15-2014, 09:09 PM
Thanks. I would have figured metric
Old 05-16-2014, 10:23 AM
crop harvester crop harvester is offline
crop harvester has a very good reputation on FTE.crop harvester has a very good reputation on FTE.crop harvester has a very good reputation on FTE.crop harvester has a very good reputation on FTE.
You can use a fly wheel turning/holding tool,it looks like a pry bar with a bracket attached.
Old 05-16-2014, 04:47 PM
Thanks guys. Got it. Used long 8mm bolts ( it was metric glad i grabbed both) and put rod across it to frame. Everything loctited and waiting on help to get tranny and tcase back in.
Old 05-16-2014, 08:24 PM
Bill Kay Bill Kay is online now
Bill Kay is gaining momentum as a positive member of FTE.
I'm probably not telling you anything you don't already know but that is one heavy transmission. When you go to stab it back in, once the input shaft is through the clutch disc keep the up, down, side to side movement to a minimum. If you let it go to far it will bend your center section of the clutch causing the clutch to be warped and it WILL chatter if you do. I bought a $129 harbor freight trans jack when I did mine and it was one of my more intelligent purchases. With up down, tilt front to back and side to side you can get it perfectly lined up and it is oh so much easier when it is lined up.
Good luck!!
For Sale - '88 AOD Transmission with Flywheel FOEngineer New Hampshire Chapter 0 10-10-2016 01:52 PM
Flywheel bolts coming loose F-100project Ford Inline Six, 200, 250, 4.9L / 300 10 08-27-2016 07:34 PM
Flywheel and Pressure Plate Torque Specs NS70250 1967 - 1972 F-100 & Larger F-Series Trucks 0 04-09-2016 03:35 PM
96 flywheel bolts strokechoke96 1994.5 - 1997 7.3L Power Stroke Diesel 0 09-08-2015 08:17 PM
flywheel & pressure plate torque specs Crazz Clutch, Transmission, Differential, Axle & Transfer Case 0 10-06-2004 07:53 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
