Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Old 11-20-2014, 07:43 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Brake Guides
Print Wikipost
C900 Master Cylinder fill ?
Old 05-15-2014, 03:29 PM
DodgeAddict's Avatar
DodgeAddict
DodgeAddict is offline
After putting all new cylinders & shoes along with the brake lines it comes time to fill the master so I can vacuum bleed the system.
How do you fill the Master?
Thanks ahead! Bob
It is a 1970 C900 with a single system
<input id="mac_address" value="" type="hidden"><input id="mac_address" value="" type="hidden">
Old 05-15-2014, 03:49 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,579 Likes on 1,288 Posts
I do not have time to find it right now, but iirc, you have to pour it in from the back, a real pita process.
If you google it, you will find several references to it. You may have to try several wordings to hit it.
I'll check back later and search it out if need be.
Old 05-15-2014, 10:48 PM
85e150's Avatar
85e150
Old 05-17-2014, 03:59 AM
big job's Avatar
big job
big job is offline
Its the little things that drive ya nuts. Anyways you have to tilt the cab
up and peel the rubber boot up. We fill a squirt oil can with brake fluid
thats the only way for no mess. I have all the master Ford manuals and
no where this is mentioned. Go slow cause there is a baffle cast in there
so it doesnt leak on the drivers foot. (brake & Clutch)
A C900 with juice brakes? *&*+$#?
JWA
07-17-2011 01:15 PM
ham4ever
11-09-2004 02:15 PM
gbickford
04-30-2004 03:12 PM
CRJ900
18
07-08-2002 10:42 PM
desperado
06-19-2001 06:29 PM
Quick Reply: C900 Master Cylinder fill ?
