Ive no clue does the e4od mlpslook different? Mines tan and look basically like the one u posted other then color cause if thats the case I need one for my e4od
You just tighten the screws.
The MLPS you align the marks with it in neutral.
Mine doesnt look exactly.like this its tan has ears on the sides for the connector doesnt have that tab on the left side and has the fotp-7f293-AA on it
It does look like that.. hmmm then why doesnt it line up? If I line the trans grooves up with the.mlps thats when I got reverse as park. But if I put it in nuetral I have to spin the mlps to.be able to bolt it in. So then its outa wack again.
There should be two key bumps in the sensor and two groves on the shaft.
With it slipped on to the shaft and in these groves and then you turn it untill the lines line up while in "N" and tighten down the two bolts.
If the screws at the bottom of the column are tight and the brackets that hold the cable under the truck are in tack it should all line up with the pointer in the cluster pointing at "N".
Did you ever say what year you are working on?
Yeah its a 93 f250 like I said its odd like my prndl shifter doesnt go to 1? Unless it is but the little needle doesnt match the levers position. Like it goes to two and stops.
Really wish I wouldnt even have tried this... it is odd like reverse is park cause thats the only way itll turn on now
And so I guess n is reverse d is n and 2 is drive..
