6.0 Help! I'm Stumped - Page 2 - Ford Truck Enthusiasts Forums
Old 05-15-2014, 09:42 PM
78fordman's Avatar
78fordman 78fordman is offline
78fordman has a good reputation on FTE.78fordman has a good reputation on FTE.78fordman has a good reputation on FTE.
It could but you would get random low circuit codes too. Have you checked for excessive fuel aeration?
Sent from my leash using IB AutoGroup
Old 05-15-2014, 09:48 PM
BigStyle BigStyle is offline
BigStyle is starting off with a positive reputation.
No I haven't. How would I accurately check that? I had just filled up and 10 miles down the road the problem started.
Old 05-15-2014, 09:56 PM
Bullitt390's Avatar
Bullitt390 Bullitt390 is online now
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
Bad copper washers will allow combustion gas into the fuel system and then aerate throughout the system taking out injectors.
Josh
Old 05-15-2014, 10:02 PM
Gotcha. So no more testing until I have the new oring kits.
Old 05-15-2014, 10:13 PM
78fordman's Avatar
Quote:
Bad fuel?
Old 05-15-2014, 10:15 PM
It is a fuel station I have used many times. Also a friend of mine continuously fills up at the same station. He has a dodge, but he has not had any issues. Very frustrating dealing with the 6.0 I much prefer the 7.3's I've had in the past. Only time the hood was up on them was to change oil and top up washer fluid!
The 6.0...not so much!
Old 05-15-2014, 10:23 PM
Bullitt390's Avatar
Blaming the 6.0 because you removed injectors and re-installed without new crush washers or o-rings?
Josh
Old 05-15-2014, 10:29 PM
No..because I've put more money into 1 6.0 than into the previous 5 7.3 combined!
Old 05-15-2014, 10:35 PM
Also, if it were aeration would that cause it to not start when its warmed up? Acts more like an oil leak in the high pressure side. No injectors have any deterioration of the oring from a leaking rail.
Old 05-16-2014, 06:37 PM
So today I changed injector one out with injector 7. The imbalance code shifted to injector 7. However, it still would not restart after getting warm. HPOP pressure is around 350psi when cranking when hot. I assume since before I pulled any injectors I didn't have this problem It must be a bad o-ring between the injector and the oil rail.
So is it possible that the seal is bad on the injector with the imbalance (which isn't there cold) and that replacing that seal (well all on that side) could quite likely fix the problem with the imbalance too?
Old 05-16-2014, 08:11 PM
9228.bobcat's Avatar
9228.bobcat 9228.bobcat is offline
9228.bobcat has a great reputation on FTE.9228.bobcat has a great reputation on FTE.9228.bobcat has a great reputation on FTE.9228.bobcat has a great reputation on FTE.
I hate 7.3's. Biggest pos out there.
Old 05-16-2014, 11:50 PM
BLADE35's Avatar
BLADE35 BLADE35 is online now
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
You may have a HPO Leak if the IPR% was 28% and Truck was EOT Above 185*f
PLUS those washers need chnge
Sounds like the Diagnostic was Corupt That always costs extra
6.0L - Difference between model years bismic 6.0L Power Stroke Diesel 34 12-29-2016 12:18 AM
06 6.0 Runs Smooth but Low Power Rusty Axlerod 6.0L Power Stroke Diesel 206 10-16-2016 11:39 PM
Still no start. Ideas??? phantomphixer 6.0L Power Stroke Diesel 19 04-06-2016 09:23 PM
P0275 Cylinder 5 contribution code...additional thoughts KC Excursion 6.0L Power Stroke Diesel 7 03-05-2016 09:15 PM
Strange oil leak miker67 1999 - 2003 7.3L Power Stroke Diesel 4 01-06-2015 07:48 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
