Stamped on my 1950 F1 cowl next to the VIN plate is 528K5672. What does it stand for? The VIN plate reads 98RC 268072 ATL, same numbers on the frame and glove box door.
Are you sure that is correct? The stampings were generally
letter(paint) one or two letters(plant) one or two numbers (day) letter(month) numbers(production # on line)
Are the stamped numbers in the center of the cowl, or right next to the tag? I suspect you are looking at a different number. Should look something like below
That stamp next to the VIN plate doesn't make any sense to me. But here is the decoder for your VIN.
The first character of the 48-50 vins is year 8 - 48; 9 - 49;50
The second and third characters indicate engine 8R for V8; 7H for sixes
The 4th character is model, for example: F1 model code is C; F2/3 code is D and later (around 110,000) split into D/Y respectively; F4 - F6 listed as T
Then, up to 6 digits complete the vin
The pictures show the location of the cowl stamp on my St. Paul built '50 F2.
