New Toyo Mt's are c-rated?
I agree with Stuart and CuNmUd, those tires are rated for more than enough to safely carry your truck. Load ranges can be misleading, at the end of the day the weight rating of the tire is what determines whether or not it's safe to mount.
Make sure to NOT exceed 35 PSI with those things though. You have a much wider footprint than the stock size, so they don't need nearly as much pressure as stock tires to carry the same weight.
My only question would be a legality one, if he is in a accident can that be used against him, it says right on the door sticker load range E , It is kinda like going over your weight's that are posted on the door pilar sticker, those are the legal weights your truck can carry with E rated tires..
on
Whenever you deviate from stock specs you risk becoming liable for a safety hazard. The sticker doesn't just state the load range of the tires, but the size as well. For example the OP could be liable for rear ending someone because someone makes the argument that the factory brakes aren't adequate to stop tires that large.
As Brent said, the tires are rated for the weight of the truck. There's no issue there.
Not so sure about that , you are taking a tire with a 6ply load range C rating putting it on a 7500 pound truck that requires a 10ply E rated tire and thinking all is dandy, My wifes car has load range C tires on it and believe me I would not put them on my Superduty no matter what the weight rating is, When he is pulling a nice heavy load and one of the C tires self destructs from to much heat injuring or killing someone your 18 year old lawyer is gonna get his *** handed to him...
