Front spring bushings
Make sure that you need to replace it. Try sliding a pin in. If it doesn't wiggle it is probably OK. Usually the front springs bushings are not as worn as the rear. If it ain't broke don't fix it
If it is worn just use a sawsall or a hacksaw blade to cut the bushing. Usually you only need one cut to relieve the pressure but in stubborn cases you may need multiple cuts then remove the bushing in pieces. Use plenty of PB Blaster first.
Thanks for the reply. Unfortunately, I should have left it alone, but I got talked into removing it by my buddies. In the process I ruined it. I tried the hacksaw approach with no luck andthen tried heating it. After that, I took a drill to it, and now the shackle hole is elongated.
stlouis55
You could cut the rivets (replace with bolts) and take the spring shackle to a machine shop and have them press it out and the new one in. They are made of steel with a copper machined surface I believe.
I'm pretty sure I used a chisel on mine to get them out.
I'm in St Charles, MO
I found a piece of threaded bar that was large enough to screw into the bush and bite into it fairly hard, then used a hammer on the end of the threaded bar to drive the bush out, easy. If the hole is only a little elongated it will still be ok, the bush is just a brass tube, use a slightly thicker wall bush, press it in and it will deform to the elongated hole, ream to size and you're done.
fisherman_chuck
07-28-2018 06:47 AM
