Vacuum Wipers
Vacuum Wipers
Hello to all and every day is a good day to go truckin'!
...and some days it rains... So, I've been thinking of different ways to have my wipers work without having to convert to electric. The electric kits won't fit because of my stock radio.
Does anyone know how much vacuum is needed to operate the wipers? Is it possible to use a 6v vacuum pump and switch independent of the vehicle vacuum line? Seems the independent pump is the way to go, but need to find one strong enough. Hence the need to know the strength or draw needed.
As always, thanks for your collective input.
Tony
Tony
I dont know about 6v but for 12v I want to try one of these inline with the engine vacuum. I have one on the shelf I tried as a standalone in my 37 buick and it was not strong enough to work on its own but may work in tandem with the engine.
http://www.ebay.com/itm/1998-2003-VW-PASSAT-CRUISE-CONTROL-VACUUM-PUMP-811-907-325-OEM-/271321686670?pt=Motors_Car_Truck_Parts_Accessories&hash=item3f2c08628e&vxp=mtr
The vac wipers use a ton of volume, I think the best you can expect from adding a canister is to get over a medium sized hill before it peters out.
