370 ?? on two bolt holes. - Ford Truck Enthusiasts Forums
Old 05-14-2014, 05:18 PM
MOERULES MOERULES is offline
MOERULES is starting off with a positive reputation.
Just had my 370 rebuilt and have two open holes in the block I am not sure what goes in them. One is to the right of the fuel pump at the same level looks to be a oil passage or?? The other is on the passenger side of engine about an inch towards front engine between trans and head also appears to be oil passage. Just not sure if they are just suppose to be plugged as I have nothing left to put in those two spots. Thanks.
Old 05-29-2014, 02:38 AM
fuzzybob's Avatar
fuzzybob fuzzybob is offline
fuzzybob is gaining momentum as a positive member of FTE.
Moe, there's a block drain on each side of the engine.
The skinny on EBPV pedestal gut and plug, already done it - take note Snowseeker 1999 - 2003 7.3L Power Stroke Diesel 55 06-25-2016 10:10 PM
Coolant passages in heads, f150 intake. Bullitt233 1987 - 1996 F150 & Larger F-Series Trucks 5 12-11-2015 10:05 AM
Help With 370-4v - 429/460 Swap !! jmss123 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 9 08-19-2015 09:33 AM
2003 Expedition wiper motor repair punchback 1997-2006 Expedition & Navigator 6 03-08-2015 06:52 PM
Valve lifter orientation John Irwin 6.0L Power Stroke Diesel 3 07-26-2014 07:40 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
