99 F250 turn signal won't work - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 05-14-2014, 01:46 PM
bama7x57 bama7x57 is offline
bama7x57 is starting off with a positive reputation.
I picked up a used F250 and everything seems to work except the turn signals. All hazards and all brake lights work. I have tried another known good multifunction switch, a known good flasher relay and the fuses check good. What else can it be?
'04 F-250 keeps blowing #18 20a turn signal fuse Tampa250 6.0L Power Stroke Diesel 8 01-20-2016 09:18 PM
Horn and turn signals not working. elymashburn 1997 - 2003 F150 0 09-23-2015 04:32 PM
Turn signals bks976 1999 to 2016 Super Duty 2 07-12-2015 05:06 PM
1997 f 150 no rear turn signals or stop lights ashleyroachclip 1997 - 2003 F150 3 06-13-2014 10:38 PM
Turn signals failed randomguy 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 12-31-2013 04:23 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
