Exhaust Question - Ford Truck Enthusiasts Forums
Exhaust Question
Old 05-14-2014, 11:09 AM
79Ranger250 79Ranger250 is offline
79Ranger250 is starting off with a positive reputation.
Exhaust Question
What is the difference between what y'all call "true dual exhaust" and whatever kindof exhaust people say is dual?
Old 05-14-2014, 11:28 AM
Mr7.50headsup's Avatar
Mr7.50headsup Mr7.50headsup is offline
Mr7.50headsup is starting off with a positive reputation.
A "true dual" exhaust is two independent exhaust pipes from the manifolds/headders to the exhaust finishing point.
When dual exhaust is not a true dual is where the manifolds/headders meet at a common single pipe to a muffler that splits into two separate pipes to the finish, as found on every "cat back" exhaust system for modern cars and truck. Or even the more offensive inline 4 or 6 cylinder with only one exhaust bank that is split into two pipes at the muffler.
It is generally excepted for the most power to be generated from an exhaust it should be a "H" pipe system. A true dual system with a pipe about 2 feet back from the collectors to equalize pressure. Making the exhaust form an H with the piping
Old 05-14-2014, 12:02 PM
Well I guess I'm runnin true duals and I didn't even know it, thanks for the help
Dual exhaust 77 2wd 1973 - 1979 F-100 & Larger F-Series Trucks 14 08-25-2012 11:42 PM
How much would you pay for diesel true dual exhaust? parkland General Diesel Discussion 11 04-18-2012 01:52 PM
Dual Exhaust mtntop1 1987 - 1996 F150 & Larger F-Series Trucks 15 10-13-2011 09:25 PM
F150 4.9 dual exhaust? 2002exPSD 1987 - 1996 F150 & Larger F-Series Trucks 20 02-11-2011 03:50 PM
true dual exhaust Pastmaster 1997 - 2003 F150 3 03-23-2000 10:33 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
