Leaking Oil Plug/Orings on Head
That is a tough one to find.. usually i can find torque specs pretty fast.
I wouldn't use loctite, I see no need for it. Plus i don't want that stuff to crust up and travel through the system. Especially if you ever remove those plugs. if you loctited them the crude can fall in the next time you pull them out. And if you don't clean those oily threads throughly, the loctite don't really work well anyways.. I just don't see the need for it.. I would just put a little oil on the orings and tighten them up. IF i was going to grab the torque wrench i would use 20ftlbs.
https://www.ford-trucks.com/forums/1...ing-heads.html
BadDogKuzz
02-14-2012 01:01 PM
hucka1a
12-12-2005 04:38 PM
