How to Flush & Refill coolant to 50% mix? - Ford Truck Enthusiasts Forums
Old 05-13-2014, 09:51 PM
Keny1's Avatar
Keny1 Keny1 is offline
Keny1 is starting off with a positive reputation.
Hi All and thanks in advance!
I bought a extended 2012 E350 with 5.4 liter engine with 58K miles on it. I want to drain, flush, & refill with coolant so I end up with a 50/50% mix of coolant and water. Only when I drain the system, about 1/2 of the coolant will not drain. How do I now add anti-freeze so I end up with a 50% mix?
Are there additional drains on the block and drains for the rear heater? Any suggestions are welcome.
Thanks Kenny Lyon
www.goldwingracingproject.info
temp shows 208-210 smiley87 Modular V10 (6.8l) 6 06-25-2015 08:07 AM
Help with coolant flush and fill 2001 Navigator 68bluebeast 1997-2006 Expedition & Navigator 1 03-08-2015 09:48 PM
Coolant flush and fill and power steering flush and fill? awq134 2009 - 2014 F150 13 04-09-2012 06:55 AM
Location of ABS antilock brake control module on 1999 E350 V10 Keny1 1968-2013 Full Size Vans 2 09-09-2011 08:48 AM
coolant mix ratio question 2danglong 1999 - 2003 7.3L Power Stroke Diesel 11 06-08-2005 10:24 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
