1993 F250 2WD E4OD transmission concern - Ford Truck Enthusiasts Forums
Old 12-31-1969, 07:00 PM
Guest
Posts: n/a
Old 04-30-2002, 12:24 AM
sweitzel sweitzel is offline
sweitzel is starting off with a positive reputation.
Post 1993 F250 2WD E4OD transmission concern
In February, I bought this very nice 1993 F250. My first truck after a long line of cars and vans. It's a 5.8L and it has 125,000 miles on it. I didn't really know much of it's history, but everything about it was clean and appeared well taken care of. Having worked on my VW's, my Saturn, and my Plymouth mini van for the last 10 years, I felt that my automotive skills would be enough to keep this higher mileage truck running as my daily driver.
Recently the transmission has been exhibiting an odd behavior that I hadn't ever experienced before. While driving normally, around 50mph with the transmission in OD, if i lightly goose the gas, i get a very apparent vibration/soft groaning noise that is easlily heard and felt in the cab. If i goose it harder, the noise disappears and the trans upshifts to 3rd as it should. If I keep the trans into 3rd by hitting the OD off button, the symptom basically disappears. I started doing research and have gotten very confused. Some sites say that I am hearing Torque Converter Clutch (TCC) shudder. Some places say this is an early warning of a Torque Converter failure. Some other places say that this is a common design flaw and can be eliminated with inline wiring harness micro-processor controllers. Yet other places say that a new solenoid shift pack is needed. I guess my question is, is there a way to narrow down whether my TC is failing? or should I start with micro-processors to increase the trans line pressures? The fluid level is proper. The fluid itself is clean, healthy pink in color and does not smell burned. The trans doesn't appear to be leaking at all. I do not know when it was last serviced with a filter. I plan to try this first. If I don't manage to get to do a service for a few hundred more miles, do you think that i run the risk of extreme damage?
I thank everyone who took the time to read this
-sean
Old 04-30-2002, 11:13 AM
jimandmandy jimandmandy is offline
jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.
This is a very common problem with E4OD. There is no risk of damage, but start saving up for a new converter. Mine went out at 115k, about average, according to the trans shop. You will suddenly get VERY hard shifting when it finally fails. This is from the computer maxing out the hydraulic pressure to get the clutch to hook up. You can still drive it after that, but you will want to get it fixed.
I had the whole transmission rebuilt, but it was expensive, $1800. Without the slippage, my highway gas mileage has improved by 2-3 mpg.
Old 04-30-2002, 02:28 PM
RichR RichR is offline
RichR is starting off with a positive reputation.
I am having the same problem with my 95 Bronco with 5.8 E40D 143k. It was doing the same thing TC shudder. I had the fluid and filter changed and drained the TC also added a bottle of Lubeguard. The problem went away and was shifting smoother for about 3 weeks. Now I am getting the code for TC slipping and it is going into FMEM mode causing the pressure shifts. I reset the code and it will shift smooth for awhile then it gets the code again. I am preparing for a tranny re-build. It may be that the fluid and filter change may buy you some time.
Old 05-11-2002, 08:46 PM
mrak2 mrak2 is offline
mrak2 is starting off with a positive reputation.
How do you scan transmission codes? Can I do it with the auto x-ray EECiv scanner for the OBD I, or is a seperate tool needed? I am having similar problems.
Matt
Old 05-14-2002, 11:02 AM
jim henderson jim henderson is offline
jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.
Yeah that sounds like torque shudder, it is a sign of impending TC failure and it was common on E4OD upto I think 1995 I was told by my tranny shop. IT can be bandaided by using electronic controllers or shift packs which kick up the pressure, but the TC will eventually fail and it can cause some problems as it starts to release particles into the fluid and or overheats it. So a rebuild is in order.
I had mine rebuilt to be "bullet proof" while towing an 8,000lb trailer so it cost me about $2,300? for rebuild with best clutches, heavy duty pump, new valve body, shift kit and new spec TC, plus odds and ends.
Good luck,
Jim Henderson
Old 05-14-2002, 12:34 PM
Transmission codes are scanned the same as engine and ABS. It's all in the same computer memory. The torque converter codes are 94, 62, 627, 628, and 629.
Jim
Old 09-06-2007, 01:11 AM
h2oskeez h2oskeez is offline
h2oskeez is starting off with a positive reputation.
I don't know if this is the right time or place to add a couple of cents but you guys really sound like you know what you're talkin' about and I'm a newbie. I bought a 92 that wouldn't go into reverse, dorve it until it wouldn't go forward either ( I know... bad, but money was tight) had it rebuilt w/all new goodies inside but it never felt right, then I heard that I may have the driveshaft and slip shaft 90 or 180 degrees out and now out of balance ?? Any ideas plus I'm getting an E 03 fault code? in the digital odometer.
Old 09-06-2007, 12:13 PM
quicklook2's Avatar
quicklook2 quicklook2 is offline
quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.
before you do anything else do this:
drop pan, replace filter with a ford filter, drain convertor, (do not skip this) replace with good fluid read the labels and buy one that says good for tranny shudder, use a bottle of lucas trans. fluid, it is thick and should not go in first maybe after 1 gallon of fluid. it helps to put it in boiling water to thin out. get a bottle of s'shudder fixx' do a search on google.
this is worth trying first.
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 04:27 PM
Can someone explain this to me? 1987 - 1996 F150 & Larger F-Series Trucks 11 03-09-2016 01:40 PM
ooops Aerostar 5 01-14-2015 04:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 07:14 AM
DPSE Roachfood 1987 - 1996 F150 & Larger F-Series Trucks 3 03-11-2002 11:21 PM
Tags
1993, 1995, 250, 2wd, 628, e40d, e4od, f250, ford, harness, lucas, shutters, tramission, transmission, transmissions, viborates, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
