How to remove heater control panel?
I have a 1988 F-450 and both cables that control cab heat temperature and defrost are either seized or broken (no A/C). How do I remove the plastic panel that holds these controls? I need to replace the cables but I don't see any screws attaching the panel and I don't want to just start prying on it. Thanks for the help.
Randy
Randy
Depending on your year, you may be able to use an upgraded cable. The 95 year switched the design of the temp select cable to be more durable. I just did this change on my 92 and seems to work great. From a 95 (I think up to 97) you would need the heater control panel and the cable (I think that is all). You would just remove the older parts and replace with the newer parts. Easy but does take some time. https://www.ford-trucks.com/forums/7...l#post14299385
yamagrant
10-08-2018 04:22 PM
stockcar nut
02-02-2010 07:58 PM
Duthlerfordparts
12-09-2003 01:21 PM
