Making clutch pedal easier to operate after knee injury
I have a 68 F100 with 3spd and 360 motor. After a recent knee injury, operating the clutch has become painful. I had a new clutch professionally installed about 2000 miles ago and everything seems to be working OK - just hard to operate.
Long spring underneath for throw out bearing is hooked around front of drivers side engine mount and I have what appears to be an original spring under the dash. Is there something I can do with the spring under dash to make clutch pedal easier to operate (and less painful on my knee)?
Thanks.
Thanks.
The conversion deletes the linkages and actuates the clutch fork with a "push" style external slave cylinder. The clutch (disc, plate, etc.) stays the same.
Call up Modern Driveline and speak to Paul Coffey. He can probably set you up with what you need or want: Hydraulic Clutch Kits, Mustang, Falcon, Hot Rods - Modern Driveline
.... or contact American Powertrain: http://americanpowertrain.com/c-6369...plete-kit.html
phoneman91
02-24-2012 01:48 AM
theleetbeagle
11-08-2005 10:51 PM
rmalottwtes30
07-03-2005 08:58 PM
