Trailer tires life expectancy
Old 05-13-2014, 02:42 AM
djm1204's Avatar
djm1204
djm1204 is offline
Just curious - a general answer will be great - how long do your trailer tires generally last ?
I am asking mileage wise rather than time wise !
Old 05-13-2014, 04:41 AM
bluefishgary's Avatar
bluefishgary
bluefishgary is offline
I run mine 3 years. I do not cover them. I just replaced all four last week, this winter was hard on them. I did find some cracking in the sidewall at the beads.
Old 05-13-2014, 05:09 AM
senix's Avatar
senix
senix is online now
Received 1,415 Likes on 1,010 Posts
LT tires will run a lot of miles. ST tires about 30K.
Old 05-13-2014, 06:12 AM
Gearitis's Avatar
Gearitis
Gearitis is offline
I usually get around 20k on ST's. Again it can also depend on the axle alignment. I learned several years ago that every 20 or 30k, go ahead and have the axles aligned as it scrubs the tires. Longer trips is where I got into trouble. Here is a link that helps explain: Axle alignment critical to set wheels and tires in optimum position; TMC manual and educated technicians can help | Distributors, Upfitters content from Trailer Body Builders
Old 05-15-2014, 12:37 AM
djm1204's Avatar
djm1204
djm1204 is offline
Everyone - thank you for your responses.
Dan
Old 05-23-2014, 07:53 PM
pappy19's Avatar
pappy19
pappy19 is offline
After so many blowouts on ST tires on my Airstream, I completely changed out my 15" St's with 16" E rated LT Michelin M/S-2's. I do not worry about tread seperation any more. I will not run ST's except on my 16' utility trailer and then, I will change them every 3 years. ST's are mostly crap no matter which brand, IMHO.
msgtord
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
17
03-28-2015 04:55 PM
bobj49f2
25
07-10-2014 04:29 PM
Pig Pen Jr
03-04-2004 10:08 AM
Island Boy
10-17-2002 11:18 AM
Quick Reply: Trailer tires life expectancy
