Runs great cold, horrible when hot. - Ford Truck Enthusiasts Forums
Old 05-12-2014, 02:19 PM
Zejokee Zejokee is offline
Zejokee is starting off with a positive reputation.
I am pretty much out of ideas what is the issue with my truck. But here it is.
2004 F-350 6.0L late build - no
Back story
Started to get coolant pukage and had over 16psi pressure. Tore down the engine and found the PO used black onyx gaskets. Already had studs. Had heads machined and put everything back together. Truck ran great before the build. This is where the fun begins. No STC fitting.
Issues
Trucks starts up no problem hot or cold. Runs great when the truck is cold. Has tons of power. Once the <acronym title="Engine Oil Temp">EOT</acronym> gets above 120F it falls flat on its face. It runs really rough, lopes and misses and shakes the whole truck. It has absolutely no power. It will not rev. above 1500RPM in drive but will rev. no problem in neutral or park. In drive the truck will barely move. Has no boost either. Truck does not smoke at all. A slight smell of unburnt diesel but that's all. At first I was getting contribution / balance codes. No the same code back to back other than #5 and no more than 2 at a time. Replaced #5 injector but still randomly getting #5. I could start truck, pull codes, reset, turn off, start the truck again and have a different code each time. Totally random. I loaded up my SCT Extreme street tune and truck acts the exact same way expect I do not get any codes.
TLDR - truck runs great cold, but horrible when warm. Seems to be temperature related.
Attempted solutions and PIDS.
Double checked push rods and rocker arms. All good.
Replaced #5 injector. Code still randomly comes up.
Replaced <acronym title="Injection Pressure Regulator">IPR</acronym> valve - connector on <acronym title="Injection Pressure Regulator">IPR</acronym> broke during build
Replaced <acronym title="Injection Control Pressure">ICP</acronym> and pigtail. <acronym title="Injection Control Pressure">ICP</acronym> builds under <acronym title="Wide Open Throttle">WOT</acronym> correctly.
<acronym title="Injection Pressure Regulator">IPR</acronym> stays around 24%
<acronym title="High Pressure Oil Pump">HPOP</acronym> replaced last November.
New stand pipes and dummy plugs. No STC fitting.
All new orings and copper washers on injectors.
Polished spool valves with 1000grit wet sand paper.
Replaced <acronym title="Fuel Injector Control Module">FICM</acronym> harness. Connector to #5 was damaged and could of shorted out.
Fresh oil change T-6
Fuel pressure stays at 60psi under all conditions.
Cleaned <acronym title="Exhaust Back Pressure">EBP</acronym> and <acronym title="Manifold Absolute Pressure - MAP Sensor">MAP</acronym>.
<acronym title="Fuel Injector Control Module">FICM</acronym> voltage stays between 47-48 under all conditions.
battery(s) test out good.
Alternator puts out 14
Passed bubble test
Passed buzz test cold/hot
I think that covers everything. Might of missed something.
Old 05-12-2014, 05:04 PM
jswartz84's Avatar
jswartz84 jswartz84 is online now
jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.
So at WOT, the IPR stays at 24%?
Old 05-12-2014, 05:57 PM
69cj's Avatar
69cj 69cj is offline
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
FICM voltage is a good tool but they can show good voltage and still be going south when they warm up.
Old 05-12-2014, 06:02 PM
Quote:
Sorry, it goes to 36 at 1500psi at about 2500rpm.
Old 05-12-2014, 06:04 PM
Quote:
That was my original thought but right now I can not afford just to throw parts at it. May or may not have a job in a month due to the contract I work on is ending. Would a failing FICM account for random long cranks too? It is like it has symptoms for several different issues but not enough to point to which one.
Old 05-12-2014, 06:14 PM
04badford 04badford is offline
04badford has a spectacular reputation.04badford has a spectacular reputation.04badford has a spectacular reputation.04badford has a spectacular reputation.04badford has a spectacular reputation.04badford has a spectacular reputation.04badford has a spectacular reputation.04badford has a spectacular reputation.04badford has a spectacular reputation.04badford has a spectacular reputation.04badford has a spectacular reputation.
Take a look when cold start ficm Main ,FICM Logic , FICM Vehicle , if the main is showing 47/48 look at the other side LP , VP. also I didn't see any Turbo Values what is VGT? and do you hear the turbo spool?
Old 05-12-2014, 06:16 PM
OEM Oil cap? and don't go past the min line in Degus coolant.
Turbo spools, can't remember what VGT is at. I have proper boost when cold. Turbo doesn't have boost when hot due to injectors not firing properly. FICM L and V are both 13-13.5 during all scenarios. FICM main is 47-48.5 during all scenarios.
Old 05-12-2014, 06:17 PM
OEM oil cap, no oil aeration, proper level. Degas is at min line actually a little right now since I have drained it several times to remove it. Pressure is not going over 5psi. New cap.
Old 05-12-2014, 06:20 PM
Quote:
When cold, WOT what is the reading VGT?
with engine warm/hot take reading in park KOEO ,low, high 2500 rpm
Old 05-12-2014, 06:22 PM
How would the VGT or the turbo affect the injectors? Turbo is working properly.
Old 05-12-2014, 06:28 PM
Sticking turbo has some weird Issues , Unisome ring, turbo veins, dirty turbo from after market filter set up, turbine hitting housing, Injects don't have anything with Turbo but Turbo Issues have a lot to do with Other running Issues, Show VGT at the above Mentioned and lets rule the Turbo Out.
Old 05-12-2014, 06:31 PM
It is 67% at idle cold or hot. I'll have to check WOT tomorrow.
Old 05-12-2014, 09:16 PM
Dutter65 Dutter65 is offline
Dutter65 is starting off with a positive reputation.
I've had the same problem, I'm guessing you have injector problems. I had 2 that were just barely bad on the contribution test. Actually I had 1 that made no difference and 2 that we has to listen close too and sometimes they didn't do it. I fought this for a long time! It ran awesome cold and terrible hot. One other thing it never did give any codes!!
Old 05-12-2014, 10:09 PM
Bullitt390's Avatar
Bullitt390 Bullitt390 is offline
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
What is the ICP psi and IPR % @ WOT hot engine?
Josh
2003 Ex 7.3 Buzz Test: P1293 P1294 majestek12 Excursion - King of SUVs 0 12-11-2013 11:24 AM
1211 and 1212 codes countrycar 1999 - 2003 7.3L Power Stroke Diesel 8 11-21-2012 07:16 PM
engine miss and kill when warm. p1280, p1211 cyco 1999 - 2003 7.3L Power Stroke Diesel 3 09-24-2012 09:53 AM
EXTREMELY rough running after startup, but cleared up? WTF??? strokin'_tatsch 1994.5 - 1997 7.3L Power Stroke Diesel 27 04-03-2010 06:39 AM
knocking under load.... strokin'_tatsch 1994.5 - 1997 7.3L Power Stroke Diesel 96 03-03-2010 09:01 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
