Intermittant difficult starting/poor milage
Old 05-12-2014, 01:36 PM
fordguy55's Avatar
fordguy55
fordguy55 is offline
Hi All. Don't know if these two are related but I could use some insight. A few months ago the gas milage on my '02 Sport Trac RWD dropped significantly. Used to get 17/24 if I'd drive like grandpa Moses but now it's like 13/17. Have 106k on it. Changed the plugs and wires around 90k. Last week starting became really drawn out, like 5 full seconds or more. It seems to run perfectly normal otherwise. No CEL to indicate any problems. Not really sure where to start. What's the life of a cat converter? Any reason to suspect them? Was thinking of pulling the throttle body to see if it's gunked up but I did that last summer and cleaned it. Any help is appreciated.
Old 05-13-2014, 09:27 PM
Graygeorge's Avatar
Graygeorge
Graygeorge is offline
check fuel pressure. Should be around 50# when running & hold pressure at 50# when engine is off.
Old 05-14-2014, 07:19 AM
fordguy55's Avatar
fordguy55
Interesting. I would have thought there would be adverse effects at all ranges, especially at high speeds if there was a filter issue. Good call though. I'm way overdue for a fuel filter.
Old 05-17-2014, 05:25 AM
oneowner83's Avatar
oneowner83
oneowner83 is offline
He didn't say filter, he said fuel pressure.
Old 05-19-2014, 09:10 AM
fordguy55's Avatar
fordguy55
Yes, he did say pressure and I missed that since I was already reading some information on-line about clogged filters. Do the scan tools that parts places do for you free give the pressure readout? What about vacuum? Truck seems to be running okay and actually the gas mileage seems to be up a bit since the last fill. Still have to get to the filter. Starting has been a bit better too but still not right.
Immortal_Ben
53
03-06-2013 01:28 PM
doerun6217
Bronco II
12-22-2012 09:07 AM
0gers
1997-2006 Expedition & Navigator
05-25-2010 07:16 PM
sledhead03
Modular V10 (6.8l)
05-10-2010 11:03 AM
bazzman1953
1983 - 2012 Ranger & B-Series
13
07-15-2008 03:07 PM
Quick Reply: Intermittant difficult starting/poor milage
