Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
2002 5.4 supercharger swap into a '65 f100
Old 05-12-2014, 01:11 PM
ford5t6's Avatar
ford5t6
ford5t6 is offline
hey guy's,
i came across a 2002 5.4 supercharged engine and trans out of a f150 harley davidson.
i want to drop it in my '65 ford f100
what are the problems to expect? (exept the obvious enginemounts and trans mounts)
i like to know iff there is a basic wiring harness and ecu available?
if so where?
thanks!!
see ya
twan
Old 05-20-2014, 12:37 PM
Raider50's Avatar
Raider50
Raider50 is offline
Not entirely sure but painless wiring harness should have something to help you out with. I am not sure if it will physically fit under the hood. Unless you take the trans with that engine your going to need to put a manual behind it. The 65' probably wont be strong enough and it works off of mechanical kick down and linkage. You will probably need standalone ecu's for both engine and trans, find a really good dyno shop somewhere close and talk to them about it...This would be a extremely complex undertaking. Hope it all works out, it sounds like a cool idea.
Old 06-05-2014, 08:11 PM
joebear's Avatar
joebear
joebear is offline
Hello there. I've heard about this kind of swap,and it's a lot of work but the end result is worth it. I Ford has a harness for street rod app but it's kinda spendy. It includes almost everything (almost) for about $1800 or so. Good luck!
berriault
1997 - 2003 F150
31
12-23-2021 05:35 PM
coleaukee
1999 to 2016 Super Duty
03-24-2015 11:22 PM
Ranger GT2
Electrical Systems/Wiring
01-11-2008 05:55 PM
dixiebandit69
Modular V8 (4.6L, 5.4L)
06-10-2003 09:03 PM
Quick Reply: 2002 5.4 supercharger swap into a '65 f100
