Go Back   Ford Truck Enthusiasts Forums > Misc. > Cooling, Heating, Ventilation & A/C
Sign in using an external account
Register Forgot Password?
Old 11-07-2014, 02:40 PM
How-Tos on this Topic
Last edit by: IB Cristina
See related guides and technical advice from our community experts:
Browse all: Interior Guides
Print Wikipost
Old 07-06-2003, 07:00 PM
pcdocta pcdocta is offline
pcdocta is starting off with a positive reputation.
Air conditioning blowing only thru defrost vents
My A/C is blowing cold but only thru the defrost vents. First it was blowing normally from the dash but during acceleration or under load, the a/c would randomly blow from any vent, from the floor, dash, defrost. Now that stopped and it only blows from the defrost vents above the dash-board. Any suggestions?
1997 F-150 XLT, 4.2 Liter, V6, manual transmission.
Old 07-06-2003, 09:20 PM
canelane canelane is offline
canelane is starting off with a positive reputation.
my 92 f250 started that after i replaced the heater core. i think it is a vacuum related problem. i turn it to vent then back to a/c to get it to come out the vents. just had compressor clutch go out, so while im working on the truck anyway, might as well tear the dash apart. if i figure it out, i will post it.
Old 07-07-2003, 12:57 AM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
You have lost vacuum to the hvac controls. Def is the default setting. I would look for broken vacuum lines under the hood first. There should be 1 or 2 plastic lines coming out of the firewall somewhere. Probably near the blower motor.
Jimmy
__________________
Jimmy- FTE Moderator
88 5.0 LX Mustang
63 F100 351W/C6
Old 07-08-2003, 07:48 AM
ASH ASH is offline
ASH is starting off with a positive reputation.
Same problem with my truck. Found the vacuum controller under the dash that regulates flow between dash and defrost. After shutting off the truck, the contoller will move about 2-1/2 times before it uses the vacuum. If it is a vacuum leak, why does it hold enough vacuum to move this often? Also, what is the best way to check for leaks? The visual inspection is fine for the lines that are visible, but there are a lot of hidden hoses and connections. Hope "pcdocta" can get his problem solved. Let us know how is works out.
__________________
92 F-150 XLT Ext. Cab 4X4, 5.8L E4OD, 130K miles
Old 07-08-2003, 02:21 PM
I found the problem!! Just behind the Battery, coming out of the firewall is a plastic black tube that connects to about 4 other vacuum tubes. That black tube was cracked. I cut out the bad piece and connected the tube using a rubber vacuum hose. My A/C works!!!!!! Thanks lxman1 for the tip!!!!
Old 07-10-2003, 06:34 PM
HibbardSmith HibbardSmith is offline
HibbardSmith is starting off with a positive reputation.
Question Air conditioning blowing only thru defrost vents
I just got a 2003 Limited, V6, 4x4. My climate control behaves strangely. If it's hot out (85 - 90) and the temp is set reasonable (72) and I set it to auto, while I'm sitting after starting, the air comes out the front vents with the blower at high speed and blows cool air. As soon as I get moving and accelerate, the air moves to the defrost or the defrost and floor. If I drive for a little at hiway speeds and then back off for traffic, the air moves back to the dash vents (chest). As soon as I step on it again the air goes back to the defrost and maybe the floor. If I drive steadily at hiway speeds, it sometimes drops back down to the dash and then goes back to the defrost all by itself. Once the car cools down and the blower slows down it seems to work what I would consider normal (air out the dash and a slower fan). If during the period while the air is coming out the defrost, I select the dash vents manually, it stays up in the defrost vents. Even then it moves back and forth with changes in acceleration and deceleration.
Is this normal behavior?? It seems wrong to me and once I saw this thread, I thought I'd ask if I should try to get it fixed. It sure doesn't seem correct to me and I wanted to get some opinions.
Thanks, in advance, for any help.
Old 07-14-2003, 12:14 AM
monkeyvet monkeyvet is offline
monkeyvet is starting off with a positive reputation.
Exclamation Air conditioning blowing only thru defrost vents
Did you ever get a satisfactory answer to your question about the AC only working through the defrost vents? I wondered because I am having the same problem with my 1990 F-150.
Old 07-14-2003, 02:37 PM
I haven't received any reply at all other than your question.
What I'd really like an answer to is whether or not this is normal behavior. My dealer says it is normal because it's vaccuum operated and there's always a vaccuum drop during acceleration.
I think mine is worse than normal as it'll move from the dash to the defrost, stay there for awhile then move back and forth at random intervals while I'm holding a steady speed (50 - 70 mph). It seems like if it was just normal acceleration vaccuum decrease, it would move right back as soon as a steady speed was reached.
Please, someone comment on how this should work!
Old 07-14-2003, 08:15 PM
steve83's Avatar
steve83 steve83 is offline
steve83 is starting off with a positive reputation.
No, it's not normal and any competent service tech or advisor knows it. There's a check valve between the engine and the HVAC vacuum reservoir (glued to the evaporator cover on older trucks) that prevents the low vacuum in the engine during acceleration from draining the vacuum stored in the reservoir. You must have a leak in the HVAC vacuum system somewhere, probably under the dash, but maybe in the engine compartment.
__________________
Walk softly & carry a BIG 6!
Old 07-15-2003, 09:11 AM
Thanks Steve83. That's what I wanted to make sure of.
Old 07-16-2003, 09:20 PM
baer17 baer17 is offline
baer17 is starting off with a positive reputation.
I am having the same probablem as the first guy my ac/vent is only coming from the defrost vents and not coming out the panel. I checked under the hood and I didnt find any visable cracks or breaks in the vacum lines.
I unplugged the line from where it enters the firewall and heard the pressure/vacum release so I am thinking it is under my dash somewhere.
The red vacum line to the accuator that lifts the lever for the vents and it doesn't get any vacum what so ever at that point.
There is a small cylinder shaped object that has 2 other vacum lines going into it and when I move it, it seems to leak, but I don't want to just go out buying all the parts through the system till I find the right one anyone have any ideas on more detailed trouble shooting?
Old 07-16-2003, 11:03 PM
My 1990 hose arrangement appeared to be a little different, however, it was the only black vaccuum hose going through the firewall. The hose was cracked where the large rubber mounting portion meets the small black hose. Anyway, it is all fixed and I am happy and I thank everyone for all the help.
Old 07-30-2003, 09:31 AM
ASH ASH is offline
Same problem of AC blowing through defrost vents. I looked and listened, but cannot find any leaks in the vacuum lines. I did correct the problem without curing the vacuum leak. I simply disconnected the lever arm that connects the vacuum controller to the vent/defrost control. Then I secured one end of a piece of stiff wire to the vent/defrost control and the other end to the dash closer to the steering wheel. Now I can manually regulate air flow by pulling or pushing on the wire to flip to either vent or defrost. I have to work both the dash control and the wire depending on heat, AC, defrost, or vent. It isn't the most convenient and does not solve the vacuum leak, but I do have AC out the vents all the time.
Also, I had to move the vacuum controller since it could interfere with the manual controls I stuck in place. The vacuum controller is mounted under the dash with two screws. I moved it over so it is only holding by one screw. This way it is free to move without hitting anything under the dash. I was concerned that if I took it off and plugged the line, I might mess up the vacuum somewhere else in the system.
I did test the system and everything works fine on all settings. I still want to find the vacuum leak. Any more suggestions on that end?
__________________
Old 07-30-2003, 01:42 PM
HomerWinzlow's Avatar
HomerWinzlow HomerWinzlow is offline
HomerWinzlow is gaining momentum as a positive member of FTE.HomerWinzlow is gaining momentum as a positive member of FTE.
HibbardSmith, check the vacuum line plugged into the water control valve on your Explorer Limited, the often pull off or the water valve itself can have a vacuum leak as well.
F150 owners with 4X4 there is also a vacuum reservoir under the right front fender, and the main reservoir for all 97 and up F150 is mounted behind the battery. These can easily be the cause of vacuum problems because many vehicles get into fender benders and the tanks get cracked but body shop fails to replace them. Also check the various vaccum connectors under dash at the various vacuum door actuators.
__________________
My advice is just advice..Its free "IF THAT DONT FIX IT, SOMETHING ELSE WILL"
The most expensive tool in your box is "impatience"
IF IT AINT BROKE DONT FIX IT!!
My Missing Michelle
Old 07-31-2003, 10:52 AM
peterqb24 peterqb24 is offline
peterqb24 is starting off with a positive reputation.
On Ford F-150s...at least on 1998 models...
Check the black vacuum line at the connection near the line filter (blue + white disc) for a break or crack. The black line should be coming through the firewall on the passenger side...close to the battery.
I found that this line was actually touching the back side of my battery. The battery had a little moisture on it that leaked down and came in contact with the vacuum line...and ate right through it !
Take the time to disconnect the battery and remove it. This makes access to the whole series of vacuum lines a lot easier. If it is NOT the black line that came disconnected...at least you can easily check all of the other line connections.
Cut off the bad portion of the line and take out the piece of line still in the rubber boot. Insert the repaired line into the boot and reconnect it.
HINT: While you still have the battery removed...re-route the line so that it doesn't come in contact with any part of the battery. I even put an aluminum foil barrier between my battery and the vacuum lines to prevent future corrosion.
Similar Threads
in 4wd the a/c blows out the defroster vent?? pickupman2002 6.0L Power Stroke Diesel 21 09-24-2012 03:37 PM
Help with crazy A/C functioning wgm114 Cooling, Heating, Ventilation & A/C 1 08-12-2012 10:24 PM
Help me! A/C acting wacky wgm114 Super Duty & Heavy Duty 5 08-06-2012 07:04 AM
A/C only blows from defrost and floor Ricky Mayo Cooling, Heating, Ventilation & A/C 3 09-28-2010 10:05 PM
A/c blowing through defrost vents 300FOREVER Ranger & B-Series 5 08-03-2010 08:45 PM
Tags
ac, air, airconditioning, blows, bowing, coming, conditioning, dash, defrost, f150, ford, heat, load, moves, panel, truck, vent
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
