Clear coat over oil based?
Old 06-19-2014, 11:43 AM
greenwoodford's Avatar
greenwoodford
greenwoodford is offline
I have a trailer frame that I had reinforced and then I painted it with Rustoleum oil based paint. I thought it would be a good idea to have a clear coat sprayed on it to protect the paint before I put decking on it. A couple body shops told me their clear coat won't work with oil based non automotive paint. Is there something out there that I could use or should I just let it be and put the deck on it? Thanks for any help.
Old 06-23-2014, 12:20 AM
Beechkid's Avatar
Beechkid
Beechkid is offline
I think you can use any oil based paint but you will have to surface sand 1st.
Old 06-27-2014, 05:32 AM
yetiman38237's Avatar
yetiman38237
yetiman38237 is offline
Did you put hardener in the paint you put on? Usually will hold up nicely if you do.....I bought some of that rustoleum at Wally World to do a deck table. I have some hardener I got at rural king for their oil based paint but haven't had a chance to spray it yet. I never noticed if they had clear coat in oil base.......
Old 06-27-2014, 06:55 AM
greenwoodford
I didn't put any hardener in it; just rolled it straight onto the trailer from the can.
Old 06-27-2014, 09:17 PM
yetiman38237
I sprayed a trailer with oil based paint I got at Lowe's. I didn't use hardener and sprayed 3 coats on only waiting about 20 mins between coats.....it took about a year sitting in the sun to dry completely lol. After reading the directions you are only supposed to put on one coat every 8 hrs.....
91dirtydiesel
09-20-2011 08:05 AM
roadrash63
11-09-2010 02:53 PM
ltlvt
Paint & Bodywork
04-12-2009 02:18 PM
thefairlaneman
Paint & Bodywork
20
11-28-2006 06:09 PM
95250mac
Oil & Lubrication
09-25-2006 12:23 AM
Quick Reply: Clear coat over oil based?
