60,000 Mile Self-Service
Hey All,
Fairly new to the forum but looking for some help. I am on a budget and trying to cut my cost on my 60,000 mile service on my 1997 Flareside F150/5.4/2X2. I was quoted $724 for the following:
1. Lube Oil & Filter
2. Tire Balance & rotation
3. Multi-Point Inspection (99P)
4. Fuel Induction System Service
5. Cooling System Fluch
6. Transmission System Service
7. Major Power Steering System Service
8. Brake System flush
I am fairly good mechanically and have already had the tires done, as well as lube, oil, and changed the transmission fluid and fliter. I am looking through the Haynes manual to do the fuel filter and coolant flush, but not sure about the Fuel Induction, Power Steering or Brake services. I know that the fuel filter is a little tricky, and the detail on the Coolant flush calls out to remove the two block plugs just up from the oil pan for a more thorough flush, I can only see access to one. I believe the other is behind a pretty large frame brace that looks impossible to get to. Any pointers here or just go with the one plug.
I very much respect the service technicians and believe that they should do the more involved items but I feel confident that I could do some of the same work and add a little T.L.C. in the process. (I try to keep my truck showroom-worthy)
I would appreciate your thoughts on the other items on the list that I have not done yet and have no problem taking it to the "professionals" to do the rest of the list if that is best.
Thanks for the help!
Jeff
Jeff
Brown Dog
6.4L Power Stroke Diesel
07-31-2009 01:16 PM
msutil
08-03-2008 12:48 PM
