2003 6.0 wont start or turnover
I have a 2003 6.0 diesel truck..
All stock beside a superchip cortex,exhaust, and intake..
Truck has always ran great drove it to town today an filled it up went to crank it to leave an nothing... Doesnt turn over,doesnt click, wont do anything, and can not take the yellow wire with blue tracer and bypass the starter it still does nothing..
Throwin a few codes
P0603
P0676
P0678
P1000
Batteries are good
Oil level is good an new
Have no idea what it is but need to leave for sc got work in a few hours... Help?! Plz?!
Throwin a few codes
P0603
P0676
P0678
P1000
Batteries are good
Lets see if we can get one of the mods to move this to >> 6.0L Power Stroke Diesel - Ford Truck Enthusiasts Forums
You will get more help there.
Sean
Sean
Throwin a few codes
P0603
P0676
P0678
P1000
Batteries are good
Throwin a few codes
P0603
P0676
P0678
P1000
Batteries are good
The P0603 does not show in the book I am using but a little looking came up
with a KAM (Keep Alive Memory) ERRORE.
The fact that you can't get the starter to do anything tells me you have a power
problem. You side you tried the yellow/blue trace wire and nothing.
Do you know how to do a voltage drop test? I'll post a how to from youtube.
That is where I would start to look. The thing that can cause this type of problem
is a bad cable or ground point. The cable can "Look" good and be corroded under
the insulation and case a high resistance condition and give you problems.
Watch the video and post back what you find of it you are able to fix it.
Sean
EDIT : Thanks John!
No corrosion or damage on terminals i unhooked batteries for bout 30 mins and hooked them back up and all lights came on and needles on tach an speedo did their thing and it crunk and ran just fine, it will do this everytime but once i shut it off havin done this im back in the same boat..
BrandonLee
04-11-2016 06:24 PM
