DIFFERENT kind of oil pressure question - Ford Truck Enthusiasts Forums
Old 05-11-2014, 11:39 AM
flatheadkeith's Avatar
flatheadkeith flatheadkeith is offline
flatheadkeith is starting off with a positive reputation.
I have searched the internet several times over, and I always find different answers to the same old question...what should your oil pressure be on a FLATHEAD V8? Now...what I want to do is start this thread to see what people actually have. Can you post your type of V8, Mileage, Type of oil, and hot/cold PSI idling and running, and what type of gauge you are using? (Also if you are running a high volume pump, please specify) For Example:
I am running a fresh 239 Flathead 8BA.
Engine has less than 100 Miles.
I run 15W 40 Delo Oil.
Cold Idle- 50#
Hot Idle- 25#
Cold Running- 65#
Hot Running- 55#
MECHANICAL GAUGE!
Every post about oil pressure has what people think you should use for oil, and what they have. They always say "My flatty has 40#" but they dont say hot or cold and what type of oil they are using. The more information the better!!
Old 05-11-2014, 11:43 AM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Mine is very similar to yours, running 10w30. But this will be meaningless unless the gauge used is indicated. My dash gauge says it barely gets to 35, but a real gauge shows just what you are seeing.
Old 05-11-2014, 11:45 AM
Great point! I just edited the original post to see what people are using.
Old 05-12-2014, 07:11 AM
Johnny5 Johnny5 is offline
Johnny5 is starting off with a positive reputation.
I put a lot of faith in bobistheoilguy and I am of the understanding that 10#/1000 rpm hot is acceptable. I also am a big believer that too much oil pressure can be a bad thing from parasitic hp loss to washing out the oil at the bearings.
Just built a 239 flathead and am expecting 20-30# hot at startup on 30 wt oil. Engine is tight, the tight end of tolerance. I will repost here when I finally fire it up.
BTW, I also have a 8MC in an old Customline. An obvious transplant and it is in dire need of a rebuild. Still starts up fine and with straight 30W hot it will idle with 25#. It's running a cheap mechanical gauge from Autozone. If it didn't smoke, I wouldn't bother opening it up. Probably going to just pour Marvel in it for a few frequent oil changes and see if the rings unstick...
Old 05-12-2014, 10:32 AM
ryans88gt's Avatar
ryans88gt ryans88gt is offline
ryans88gt is gaining momentum as a positive member of FTE.ryans88gt is gaining momentum as a positive member of FTE.
10 lbs per 1000 rpm is also what I have been taught.
15 lbs minimum at idle.
Old 05-13-2014, 12:17 AM
1oldtimer's Avatar
1oldtimer 1oldtimer is offline
1oldtimer is gaining momentum as a positive member of FTE.
1947 car 239 flathead either original or very old rebuild.
20/50w
mechanical S/W gauge:
cold @ idle is 80psi
warm @ idle is 20psi
cold @ running is 100psi
warm @ running is 50psi
Stock gauge on dash:
cold pegged @ idle
warm @ idle is 18psi
cold running is pegged
warm @ running is 47psi
Oil Pressure issues--4.0 SOHC rebuild IronHorseDriver Ranger & B-Series 4 10-02-2015 01:01 AM
First Run 8BA - Have some questions dlb.motorman 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 04-19-2015 07:32 PM
97 F150 4.2 fluctuating oil pressure romeodz 1997 - 2003 F150 1 11-04-2011 10:58 PM
oil question beardshadow 1973 - 1979 F-100 & Larger F-Series Trucks 6 09-10-2011 01:03 PM
51 6 cylinder Flathead Oil Pres Question 51ford fan Flathead V8 & Flathead 6 4 01-25-2005 09:27 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
