GlowShift 3 in 1 gauge question
I posted this on the Super Duty board without any hits so I figure it might be more specific to the diesel crowd.
For those of you that have installed GlowShift's gauges, they don't recommend tying the 'Orange' dimmer wire into the dimmer wheel circuit. This note is directly from GlowShift's instruction sheet.
NOTE: Do not connect the orange wire to a dimmer wheel. This will cause the gauge lighting to flicker.
I'd like to know the location of the headlight wire that I need to tap into so the gauge will dim by design by 30% when the headlights activate either manually or automatically. Thanks in advance. Mike
Its not diesel specific. Must be a glowshift thing, as that is where my isspro gauges are wired in and they do just fine, and dim with the factory dimmer switch.
Perhaps the Glowshift cannot accept a potentiality, and has two settings, high and low.
So in that case, you wan the brown running light wire from the headlight unit. There are other locations for this wire, but I assume that is the area you are poking around.
UP_There
1999 to 2016 Super Duty
01-11-2008 11:05 AM
