Rear view camera wiring assistance request.
Yes, an F350 Crew Cab with tool box and tonneau cover. The back seat head rest also impede viewing the hitch.
If I lift myself up in the seat a little I can see the hitch head over the tool box out the real window for hitching purposes.
I do plan to install another camera out the rear of the 5th wheel for travel and seeing what the heck is going on back where I can't see. For that I am going to use a separate video screen, cable and camera for the best reception. My plan is to hook the power source up to one of my Upfitter switches so I can turn it on or off with the one of the upfitter switches.
Another thought I had was to purchase a home security camera set up with two cameras. Mount one on the rear of the RV, one on top of the in the bed tool box and power the unit off of the 110 power points in the truck on an as need basis.
Guess I could get a 3 camera set up and mount the 3rd camera on the front bumper. It could monitor clearance for pulling forward, or record a drivers view for use in court if some darn full pulls out in front of me and causes damage.
Hey jonrjen, going to pirate your nice thread where you were able to use the tailgate you got from me....
thought I'd post that if anyone needs one of the ford wiring harnesses # DC3Z-14A412-A like used above... I never got around to doing mine before I traded the truck in on the motorhome...
Free to a good home in the DFW area - also have the camera, etc...
also, LOT's of truck/5th wheel stuff available - some of it on craigslist, but much of it is free to a good home
I have enjoyed the tailgate, not only when camping, but for everyday use. I will often change out the two tailgates just to give me a fresh look to the truck. Matter of fact earlier today I pulled off the 5th wheel tailgate and installed the factory gate. It won't take a day or two and I'll be swapping back I'm sure.
That's very nice of you to offer up some of your truck and 5th wheel parts here to members on the forum. Feel free to mention what you have.
How is the motor coach glamping going?
rear view camera system
2013 F350 Lariat with the factory OEM rear view camera. I am replacing the tailgate with a 5th wheel tailgate for a few months and would like to still retain the convince of a rear view camera.
I have obtained a Ford camera harness to use as a jumper for a non OEM camera which comes with the standard basic RCA wiring which I plan to mount to the bottom of the 5th wheel tailgate.
My hope is to wire the camera direct to the Ford wire harness which is a 6 wire pigtail. Has anyone done this and be in a position to share which wires on the camera mate to which wire on the trucks wire harness.
And preferably keep it simple so even an idiot like me can understand it.
Thanks for the assistance,
https://brakelightcamera.com/product...backup-camera/
#28
2015 F350 Camera Wiring
Hello all,
I'm looking to install a license plate camera for those times when the tailgate is off and the camper is on. Here's the wiring on the (larger) truck-end of the tailgate harness I purchased to which I'll attach a camera. Unfortunately, it doesn't seem match anything else I've found on the forum. I don't know whether to trust color codes, or pin position. Anyone done this on a 2015, or have access to a wiring diagram?
Pin 1 Violet/Grey
Pin 2 White/Green
Pin 3 Brown
Pin 4 Flat black
Pin 5 Glossy black
Pin 6 Gray/Violet
Jonrjen's post is the closest I've found in terms of model years, and it doesn't match.
Pin 1 Violet/Grey +12V..............Red power wire from camera
Pin 2 Grey/Violet ????...............NOT USED
Pin 3 Brown/Violet Video -.........Bare copper wire from camera yellow video wire
Pin 4 White/Green Video +........Yellow Camera video wire
Pin 5 Black (not used)................NOT USED
Pin 6 Black -12V (grd)................Black ground wire from camera power cord.
Pin 1 Violet/Grey
Pin 2 White/Green
Pin 3 Brown
Pin 4 Flat black
Pin 5 Glossy black
Pin 6 Gray/Violet
#29
Hello all,
Pin 1 Violet/Grey
Pin 2 White/Green
Pin 3 Brown
Pin 4 Flat black
Pin 5 Glossy black
Pin 6 Gray/Violet
Pin 1 Violet/Grey
Pin 2 White/Green
Pin 3 Brown
Pin 4 Flat black
Pin 5 Glossy black
Pin 6 Gray/Violet
rmalottwtes30
03-09-2008 08:39 PM
coplin
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
05-31-2007 08:27 PM
