5.4 misfire - Ford Truck Enthusiasts Forums
5.4 misfire
Old 05-10-2014, 07:24 PM
Beach guy Beach guy is offline
Beach guy is starting off with a positive reputation.
5.4 misfire
Hi guys I have a 2002 f350 changed all plugs and have a misfire on cylinder 4 at 1300 to 1800. Pulled a 30 ft travel trailer 2500 to 4500 rpm no codes. I swaped injectors and no change. #4 plug was black and all others were good. Any ideas?? I changed iac ,coils ,o2 sensor,checked for intake leaks .also now and then #7 kicks up also?? Help me please!!
Old 05-10-2014, 09:10 PM
je5 je5 is offline
je5 is starting off with a positive reputation.
Were Motorcraft parts used?
Old 05-10-2014, 09:13 PM
No I used bwd coils bwd iac ,ngk tridium plugs . I have a v10 in my excursion and used the same parts no problems ???
Old 05-10-2014, 09:32 PM
je5 je5 is offline
Warranty #4 and #7 coils and see if misfires improve or you could swap them around and check misfire count in mode $06. Replace the blackened plugs also.
Old 05-10-2014, 09:49 PM
I've swapped them around did a fuel pressure test was at 30 dipped down to 29 running at 2000 rpm no load. Gonna pull plugs do a compression test too!!
Old 05-10-2014, 10:02 PM
je5 je5 is offline
Let us know the results. Add a teaspoon of engine oil for a wet compression test also to see how much the compression goes up.
Old 05-10-2014, 10:26 PM
Quote:
Well 0 compression #4 valve problems I'm guessing!!
Old 05-11-2014, 03:31 AM
je5 je5 is offline
Quote:
Burned valve or rocker off its platform?
Old 05-11-2014, 06:20 AM
Ya the plug was dry but black so take the valve cover off have a peak.
Old 05-11-2014, 03:35 PM
Well got the valve cover off all valve train still in place so the heads coming off!! Any tips??
Old 05-11-2014, 04:24 PM
je5 je5 is offline
Did you take the AC evaporator box off to remove the valve cover?
Borrow a bore scope and look in the cylinder through the sparkplug hole. There may be a hole in the piston. If you do not have access to one put #4 on TDC and pump compressed air in and listen for where it comes out to know where the hole is. Resealing head is difficult on a Modular. If piston is damaged you would be better off installing another engine.
Old 05-11-2014, 04:27 PM
I looked piston looks good . I left the evaporator I'm think n just a burnt valve.
Old 05-11-2014, 04:43 PM
je5 je5 is offline
Curious the mileage on this engine?
If head is reusable use the "special service" Motorcraft head gasket and clean mating surfaces with a plastic scraper and metal surface prep fluid. It will be difficult to install head in chassis without scratching it. Install new timing set.
Old 05-11-2014, 04:51 PM
Has 70,000 miles on it. I'm the second owner but I got it from a friend.it had a bad helli coil repair and burnt two plugs off!! I repaired the hello coil but still had the misfire.has to be the exhaust valve cause the plug was black but dry.im hoping!! Not much room to work that for sure!!
Old 05-11-2014, 05:30 PM
je5 je5 is offline
Thread inserts need to be aluminum for proper heat transfer of plugs. That may have also caused the valve to burn. So you want to completely repair this head instead of replacing it?
Misfire and generally running like crap BrentD22 1997 - 2003 F150 4 01-27-2017 12:07 AM
P0301 Misfire Cylinder 1 - Number 6 & 9 Misfire Detected Hilt6 Modular V10 (6.8l) 4 07-26-2016 07:49 PM
4.9 runs terrible 76250_4x4 1987 - 1996 F150 & Larger F-Series Trucks 33 01-18-2011 07:52 PM
4.6 Hesitation. Misfiring? mnjason Modular V8 (4.6L, 5.4L) 3 01-21-2009 11:47 AM
2000 F150 5.4L shaking , misfiring bad merlin3 1997 - 2003 F150 7 02-28-2008 03:30 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
