2001-F350-Diesel-Starter Problem - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 05-10-2014, 06:41 PM
desertjim desertjim is offline
desertjim is starting off with a positive reputation.
Hi Everyone,
When I try to start my truck, all I get is a CLICK down around the starter. I haven't pulled the starter yet because I wanted to ask you folks about it.
My batteries are good! I replaced the starter less than a year ago, I think, but I can't find the paperwork or anything to indicate when or from whom I purchased the starter. BTW, the truck only has 87k on it.
You youngster won't have any idea what I'm about to say here, so go ahead and turn your head . Back in the day, I had to rebuild many solenoids. It was easy! Just take the thing apart and reverse the copper washer which made the contact, and you were off and running again. I haven't looked at or into any solenoid in more than fifty years probably, but the point is.........that's the same sound the starter makes (like it did back then). So...........
1. Does it sound like a solenoid?
2. Do I need to remove the starter to take off the solenoid?
3. Whaddaya think in general?
I'm gonna have a worker of mine who is helping me do a barn addition pull it Monday. I gotta have that sucker running again. Can't go to the flea market to set up without it.
Donka!
Old 05-11-2014, 02:58 AM
1969furd 1969furd is offline
1969furd is starting off with a positive reputation.
try this. take a hammer, and GENTLY tap on the starter body then try and kick it over see if that works, if not then id try the sylanoid
Old 05-11-2014, 08:15 AM
Hotrod70d's Avatar
Hotrod70d Hotrod70d is offline
Hotrod70d is starting off with a positive reputation.
If the wires are not corroded at the starter . My have a dead spot in the selenoid. Hitting with a hammer while trying to turn it over is short term to getting it started . Also 2 people are required. Hopefully just the wires. They make acid cleaner in a spray then get a protective coating for wires
Why won't my truck start? Should be in FAQs Janet_W 1997 - 2003 F150 11 10-22-2015 09:04 PM
Starter solenoid sticking? One Sock 1987 - 1996 F150 & Larger F-Series Trucks 2 10-26-2014 07:34 PM
re-wiring the starter solenoid... granny_rocket 1994.5 - 1997 7.3L Power Stroke Diesel 21 01-11-2014 07:26 AM
starter problems from bad engine block ground? OldWoodsDiesel 1994.5 - 1997 7.3L Power Stroke Diesel 2 07-23-2013 02:37 PM
Starting issue nickw059 1973 - 1979 F-100 & Larger F-Series Trucks 0 08-05-2012 05:43 PM
Tags
2001, diesel, f350, heavy-duty, solenoid, starter
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
