Installed: A-Pillar Single Gauge Pod - Ford Truck Enthusiasts Forums
Old 05-10-2014, 01:01 PM
gDMJoe's Avatar
gDMJoe gDMJoe is offline
gDMJoe has a very good reputation on FTE.gDMJoe has a very good reputation on FTE.gDMJoe has a very good reputation on FTE.
Moving the scan gauge from the ROUSH dash vent gauge pod ...
To an A-pillar guage pod ...
Parts Inventory:
  • A-pillar 2-1/16" single gauge pod from - part # 15212 (intended for 2002-2009 Dodge Ram) *Currently there is no offering for the 2009+ F-150s.
  • (optional) LH windshield moulding (A-pillar trim) from FoMoCo - part # 9L3Z-1503599-CA (Charcoal Black) *Could modify existing trim.
  • 3M™ Automotive Acrylic Plus Attachment Tape - part # 06383 (7/8")
  • SEM CLASSIC COAT FLEXIBLE COATING Midnight Black - part # 17013
How-To:
  1. with the A-pillar trim as a fitment gauge, use a heat gun to carefully contort the sides of the gauge pod to conform to the outer contours of the A-pillar trim.
  2. drill a hole in A-pillar trim to allow any wiring, hoses, etc. to pass thru to the pod and eventually the installed guage. *Insure that the hole will be within the length of the position of the pod on the trim.
  3. clean (with soap and water) and degrease (with isopropyl alcohol) the A-pillar trim, the exterior of the gauge pod, AND the interior sides of the gauge pod.
  4. apply the attachment tape to either the pod's mounting position on the outer edge of the A-pillar trim -OR- the inside bottom edges of the pod's sides.
  5. attach the pod to the A-pillar trim and use small clamps along each edge to allow the tape to seat/seal.
  6. clean (with soap and water) and degrease (with isopropyl alcohol) the trim/pod assembly.
  7. when thoroughly dry, apply the flexible coating paint and let dry.
  8. run any necessary wiring, hoses, etc. to and then thru the trim/pod assembly.
  9. (re)install A-pillar trim (with gauge pod).
  10. connect any necessary wiring, hoses, etc. to the gauge.
  11. install the gauge.
Acknowledgement to NGA PLZ for paving-the-way for this mod' ...
Homemade Pillar Pod and Boost Gauge for Eco
-click- the pic'
Goth 150
< This space intentionally -blank- >
Old 05-10-2014, 01:53 PM
PrinceValium's Avatar
PrinceValium PrinceValium is offline
PrinceValium is a name known to allPrinceValium is a name known to allPrinceValium is a name known to allPrinceValium is a name known to allPrinceValium is a name known to allPrinceValium is a name known to all
Nice write up! I have thought about adding. A boost gauge on the pilar for awhile now. I wouldn't want it in the vent. When I am ready I will look into doing this! Reps sent!
Old 05-10-2014, 02:23 PM
2ndStroke's Avatar
2ndStroke 2ndStroke is offline
2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation
Very nice
Old 05-11-2014, 01:17 PM
meborder's Avatar
meborder meborder is offline
meborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant future
Fantastic Job!
Added a link to the "common mod's" sticky.
nicely done!
Old 05-12-2014, 01:40 PM
gDMJoe's Avatar
For those concerned about explosive bolts, jettisoned objects, and front, side air-curtain deployment ...
When the A-pillar air-curtain deploys it kicks-out the trim at the top and pushes past it leaving the trim/moulding still attached to the A-pillar.
There are 2 clips of different construct that retain the trim/moulding ...
  1. close to the top.
    • This clip is made to separate at its top, narrow tip. *Learned the hard way that you have to carefully pull the top part of the trim/moulding to remove it otherwise it separates and can drop-down into the cab inner/outer wall.
    • the clip fits into a slot in the A-pillar that is behind the air-curtain.
  2. ~¾ the way down from the top.
    • this clip is a typical panel clip - teeth grip the plastic pillar on the trim/moulding and the head fits into a slot in the A-pillar.
    • given that the air-curtain is folded and only extends down (say) 4" from the top of the A-pillar and the fact that the clip is further forward (e.g. closer to the windshield), it doesn't come into any consideration when/if the air-curtain deploys.
When the air-curtain deploys ...
  1. it's expansion pushes past the top of the trim/moulding though may(?) cause it to be slightly out and away from the A-pillar.
  2. the air-curtain extends rearward along the side glass until fully deployed and then deflates.
  3. the lower portion of the trim/moulding remains attached (somewhat) to the A-pillar, however, may be askew at the top
When I installed the scan guage, I left ~12" of wire within the trim/moulding+pod -and- its connection to the guage is a plug and is not bolted/screwed to any post(s). THINKING: Even if the trim/moulding+pod is TOTALLY pushed-out, it has 12" before the guage could separate from the pod, and even then it's a tight/snug 2-1/16" fit.
REMEMBER ... The RH A-pillar trim/moulding (with hand grip) is bolted to the A-pillar.
References:
Old 05-12-2014, 02:07 PM
tspangle84 tspangle84 is offline
tspangle84 is gaining momentum as a positive member of FTE.tspangle84 is gaining momentum as a positive member of FTE.
Quote:
Thank you! I was just coming in to post something about this very subject, but it sounds like you did your homework.
Installed: Front Wheel Well Splash Aprons - 5.0L gDMJoe 2009 - 2014 F150 18 01-18-2016 02:54 PM
Installed: OEM Black Housing HID Headlamps + Glossy B-Pillar Covers gDMJoe 2009 - 2014 F150 6 07-13-2014 10:45 AM
Recent Mod's - Hood Graphic, Black Exhaust Tip, etc. gDMJoe 2009 - 2014 F150 5 08-26-2013 11:10 AM
Mustang "cosmetics" applied ..... gDMJoe 5.0L Coyote 2 06-11-2012 03:43 PM
Platinum Grille - PTM gDMJoe 2009 - 2014 F150 3 06-29-2011 10:16 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
