02 fuel pump - Ford Truck Enthusiasts Forums
02 fuel pump
Old 05-10-2014, 09:39 AM
toddb1 toddb1 is offline
toddb1 is starting off with a positive reputation.
02 fuel pump
I'm looking for verification on a 255lpm pump for my 02 F250, I believe they are all about the same in these trucks and was going to use a walbro 342 pump. I'll be procharging the V10 to cure it's altitude sickness
Also is the stock pressure regulator ok with the higher volume pump?
Thanks
Todd
Old 10-17-2014, 10:15 AM
rock2610d's Avatar
rock2610d rock2610d is offline
rock2610d has a good reputation on FTE.rock2610d has a good reputation on FTE.
I would like to know this too.
Will the stock regulator even increase 1:1 with boost?
Old 10-17-2014, 10:30 AM
David7.3's Avatar
David7.3 David7.3 is offline
Where is the beer?
David7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to behold
The fuel regulators wont work with boost. you will have to gut it and use the one that comes with the procharger. They also have them aftermarket, there just preset ones.
Old 10-17-2014, 12:46 PM
rock2610d's Avatar
Quote:
Are you referring to a FMU? I was hoping for a Boost referenced regulator. Not a preset unit that just increases fuel pressure to overcome injectors that are too small. Ideally a Boost referenced regulator that increases fuel pressure 1:1 with boost.
But I cannot find an adapter that lets me remove the current FPR and install an adapter to send fuel to a Boost referenced regulator.
user name Todd Rasmussen New Member Introductions 1 11-20-2015 03:50 PM
2015 F-350 6.7 Diesel oil Todd Wenke 1999 to 2016 Super Duty 12 11-08-2015 09:48 PM
950 F-1 transmission 4 speed Todd Wenke 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 11-07-2015 06:10 PM
Engine swap 1984 Todd Wenke 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 01-03-2015 08:44 AM
driver's window replacement asphaltburner 1967 - 1972 F-100 & Larger F-Series Trucks 20 05-24-2014 07:42 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
