98 F150 Questions - Ford Truck Enthusiasts Forums
98 F150 Questions
Old 05-09-2014, 10:34 PM
88-150 88-150 is offline
88-150 is starting off with a positive reputation.
98 F150 Questions
Now that I have this in the right area, let the brain picking commence!...
Recently picked up a 98 F150, auto trans, and 4wd. Has the 4.6L Tritan V8. My questioning is even after doing a complete tune up(which it needed anyhow), when i step on the gas pedal, it acts like it's going to die, then comes back alive like nothing happened. It happens at idle. When I went to back out of the driveway yesterday morning, the truck almost choked itself. Any thoughts on the matter?
I made a recording of it at idle. https://drive.google.com/file/d/0B9p...it?usp=sharing
I've always owned 80s trucks with a carb, none of that EFI stuff so I'm new to working on vehicles with it on it. If it's normal, I'll let it be but if not, I need to know what to do to fix it as it has to tow a trailor down to TN in August.
-Matt
Old 05-10-2014, 08:21 AM
Bluegrass 7 Bluegrass 7 is online now
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
Welcome to the new world of computer control.
98% of issues are represented by fault codes but some issues are not monitored.
Check for codes using a Scanner plugged into the data port under the dash near your right knee.
Other cause of your issue can be low fuel pressure.
Use gauge on fuel rail port to test the pressure. Should be in the 30 to 40 psi range.
Let us know how you make out.
Good luck.
Old 05-10-2014, 08:55 AM
Good luck.
Hey thanks for the reply. I knew there was a reason why I stayed away from EFI... anyhow, do I just stick a pressure gauge on the port or a specific gauge or... Also, any other way of getting a fault code without using a reader? Their a bit expensive up here(even to rent).
Old 05-10-2014, 10:01 AM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Check for vacuum leaks....
Old 05-10-2014, 10:11 AM
Quote:
There's a rubber elbow just off the bottom of the air intake that's dry rotted but doesn't leak. No other leaks then that.
Also noticed while driving it yesterday that there's no giddyup. The speedo and tach are doing what their doing so not sure if it's just my perception of things or if the rear is geared for towing.
Old 05-12-2014, 09:03 AM
bumpity bump
Old 05-12-2014, 09:59 AM
Where are you at with this?
What do you think the rear to do with the issue?
Good luck.
Old 05-12-2014, 10:32 AM
BFTUFF BFTUFF is offline
BFTUFF is starting off with a positive reputation.
Most auto part stores will check your codes for free or will rent you one.
Old 05-12-2014, 10:53 AM
Ok, I'll have to fetch me a preassure gauge then it sounds like. WIll report back when I can get it checked.
Write up: 2" Leveling Kit on RWD 2008 6.4L F-250 genotac-f250 1999 to 2016 Super Duty 0 01-19-2016 07:42 PM
Questions about Original Equipment on my 78 F150 CrimsonF150 1973 - 1979 F-100 & Larger F-Series Trucks 23 05-12-2015 05:01 PM
Radio and Antenna problems 1988 Ranger SolusUmbra 1987 - 1996 F150 & Larger F-Series Trucks 1 10-15-2014 10:24 AM
FYI - Bosch Relay Guide nlemerise 1999 - 2003 7.3L Power Stroke Diesel 0 09-21-2014 06:47 PM
1995 F-250 4x4 Supercab niner Vehicles for Sale 3 08-03-2014 12:56 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
