Timing chains, stock or roller? Advance or straight up?
Quality isn't cheap.
Here's some info…
Comp timing sets...Any good? ? Speed Talk
As far as advancing the timing… advance for torque… retard for top end. The last engine we did the cam grinder ( www.jonescams.com ) ground the advance into the cam so we set it heads up. The Hughes reground roller I have in one SB Mopar engine is installed +4 degrees. Same with an SB Olds I have on the stand.
Given that the early 70's-80's smog motors came from the factory with retarded timing 8 degrees advance from stock would work just fine if you are replacing a stock cam.
Back to your 500 CFM Carburator
I had a buddy awhile back who was constantly building corvair setups. Turbo charged, super charged, non charged and so on. He had a huge selection of 4V holly. Some with air boxes for the charged engines. I was using different intake manifolds almost weekly and complaining about my MPG. He stopped me one day and said throw those 2Vs away and use a 4V. So I did. I tried several ones that he had extra and could not believe the difference. A small 4V will often get tremendous performance gains with great mileage. When possible use a 4V. I had a 300 I6 that I converted to 4V 600 CFM and it really kicked it in the rear. Thanks
palmrose2
26
10-25-2017 11:37 AM
eric in iowa
05-23-2006 01:56 PM
turbo2256
01-13-2006 04:38 PM
