Timing chains, stock or roller? Advance or straight up? - Page 2 - Ford Truck Enthusiasts Forums
Old 07-15-2014, 11:14 AM
RLWEST RLWEST is offline
RLWEST is starting off with a positive reputation.
The guys at some of the specialty engine forums have been complaining about the quality of some of the low-end stuff coming in from China and India. They recommend using Cloyes or Ford Racing parts wherever possible.
Old 08-31-2014, 09:53 PM
krooser's Avatar
krooser krooser is offline
krooser is gaining momentum as a positive member of FTE.
Quote:
I second that… you want a good quality, name brand timing set. most pro's like Cloyes… I've had good luck with SA's better quality sets. You really want a good German chain… not the cr*p that comes out of India or China. Many of those are too loose right out of the box. We put a really high quality chain in my kid's new dirt modified engine this year. I didn't want to compromise even though the engine builder suggested a cheaper deal. The extra $100.00 didn't kill us but the cheap chain may have killed the engine.
Quality isn't cheap.
Here's some info…
Comp timing sets...Any good? ? Speed Talk
As far as advancing the timing… advance for torque… retard for top end. The last engine we did the cam grinder ( www.jonescams.com ) ground the advance into the cam so we set it heads up. The Hughes reground roller I have in one SB Mopar engine is installed +4 degrees. Same with an SB Olds I have on the stand.
Given that the early 70's-80's smog motors came from the factory with retarded timing 8 degrees advance from stock would work just fine if you are replacing a stock cam.
Old 09-02-2014, 12:33 AM
tjnthesky tjnthesky is offline
tjnthesky is starting off with a positive reputation.
Back to your 500 CFM Carburator
I had a buddy awhile back who was constantly building corvair setups. Turbo charged, super charged, non charged and so on. He had a huge selection of 4V holly. Some with air boxes for the charged engines. I was using different intake manifolds almost weekly and complaining about my MPG. He stopped me one day and said throw those 2Vs away and use a 4V. So I did. I tried several ones that he had extra and could not believe the difference. A small 4V will often get tremendous performance gains with great mileage. When possible use a 4V. I had a 300 I6 that I converted to 4V 600 CFM and it really kicked it in the rear. Thanks
351w distributor swap what years are interchangeable jdhudall Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 1 12-24-2016 10:28 PM
351w cam Kevin96 1987 - 1996 F150 & Larger F-Series Trucks 0 04-28-2015 12:46 AM
'94 351W roller eng cam ???? boomer1ny 1987 - 1996 F150 & Larger F-Series Trucks 15 12-13-2013 11:20 PM
Valve Spring Question fordfan28 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 5 07-28-2006 08:54 AM
Roller cam 351 question Show-N-Go LX Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 32 11-29-2005 11:59 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
