injector Cleaner Additive
The fuel blasts out the nozzle at between 3500 PSI and 20,000 PSI. A little snake oil ain't gunna improve on that. What has helped me is an additive that augments the Cetane level of the fuel, and added more lubrication to keep those tight-tolerance parts from rubbing each other the wrong way.
Diesel Kleen is probably the most popular here, but there are many others available on the market. Some use ashless two-stroke oil for the lubrication aspect, but I don't think that does anything for the Cetane level. What I'm doing is just making up for the reformulation of diesel since these trucks were manufactured.
Your oil is more crucial on the injectors than you would imagine. Oil is what powers the injectors, and it is not as cleaned as the fuel. Think about it: The fuel is pumped through the filter to the injectors and it's used and gone. The oil goes back for another round endlessly (dropping by and rubbing up against all your engine internals) until your next oil change. Sure, the fuel cycles back from the regulator overflow until it's burned off - but it's not wallowin' all over the place like a dog scratching his back on the carpet... for months on end.
I use Opti-lube XPD
Cetane improver, anti gel, and is supposed to improve lubricity (make up for lack of Sulphur) I'm a fan.
Oil and the injectors brings up another question. Last time I had my oil changed they wanted to add some oil sludge remover (don't think I have sludge as I have changed the oil every 5000 miles since I bought the truck with 21k miles). They add it to the oil, let it run for a bit then dump it with the old oil.. A benefit or more snake oil?
Sludge was a phenomenon back when the oil companies didn't have the formula right. The miracles of modern chemistry have resolved this issue (for decades), and sludge is just a bad memory. This doesn't stop people from playing on legacy fears to sell snake oil, though. Did they also try to sell you a DVD rewinder?
Rich, what are you using and at what volume per volume to raise the centane level?
As I semi-joked above, I currently don't add anything, with the simple, albeit anecdotal reasoning that an aquantence of mine has over a million miles combined on three 7.3s and has run them on nothing but diesel.........
That being said, I can buy into the argument for centane level increases to something closer to European standards assuming our engines can digest that without any side effects
I have played with many products, consulted with many knowledgeable members, and read many technical data sheets. I have yet to find very many companies willing to share the recipe for their "Secret Sauce", so that I may make a truly informed decision. I am left only with experimentation and testimonials.
I learned the Motrocraft product comes up short on what I'm looking for, so I stopped using that one (it's mostly Kerosene). Redline Diesel Fuel Catalyst works nice, but it's pricey. I saw an infomercial where this "special" oil was drawn to high heat in a fry pan (in the middle), but I have an aluminum flat pan for my French toast that warps as it heats - causing the oil to draw toward the center. Sorting all of this out is very challenging.
I am currently running Diesel Kleen, because others have had good luck with it, Stinky seems to like it, and the mix makes sense: It's not "One drop'll do yuh", and it doesn't require a $20 drum per fill-up. I just follow the instructions.
