Hey guys I need a tip or any ideas on where to adapt my fuel pressure sensor on my idi. As for my other two gauges they are egt and boost. Egt probe I hear should go in the driver side manifold by cylinder 8? And as far as boost goes I seen a guy online put his boost fitting by the snail looking thing?
And BTW my truck is a 94 7.3L with the factory turbo.
The EGT probe should go directly in front of the #4 cylinder (Second one from the front, drivers side) as the front two drivers side cylinders have the least airflow and highest EGT's.
