Disable PATS for TS 6-Position Chip
I'm thinking I want the Phoenix chip but it disables the PATS, don't really care about the PATS if it only eliminates the "chipped" key. I only have one key for my Ex and don't want to pay $75 for a new one.
Will the "alarm" horns still work if door is opened with doors locked or is the whole system down?
Will keypad still unlock the doors?
Will remotes still unlock doors?
from KT Performance website
"If you are installing the chip in an Excursion with PATS factory anti theft system, this chip will disable the PATS system.
-To eliminate the "THEFT" light, you must disconnect the red connector from the PATS module.
-The PATS module is located below the dash directly above the transmission hump in the floor.
-With the PATS disabled, any key that turns the injection will start the engine. In other words, a non-chip key will start the vehicle."
Thanks
Josh
Thanks
Josh
There is no alarm that triggers, other than the panic button on the remote.
The pats verifies the correct key is used, thus preventing a hot wired theft. It does NOT cause an "alarm" to go off.
Sent from my Sprint PC36100 using IB AutoGroup
Most 7.3L owners opt for a chip with multiple tunes so they can switch from a daily tune to a tow tune to a whatever tune, with just a push of a button or twist of a dial.
Stewart
Seven-Point-Three
09-15-2010 08:52 AM
sturzinator
09-24-2007 09:15 PM
mpdej8
1997 - 2003 F150
01-07-2002 04:26 AM
