4X4 Help - Ford Truck Enthusiasts Forums
4X4 Help
Old 05-09-2014, 12:17 PM
Leftseat Leftseat is offline
Leftseat is starting off with a positive reputation.
4X4 Help
I have a 2004 F-150 Non Heritage. The 4WD was working fine last year and is not working now. The light on the dash comes on and I do seen to be getting vacuum at the hub but it is not engaging. Several months prior to using the 4WD I did do some front end work and must have knocked the vac line off. It was off for several months, I reinstalled it and it is still not working. I could use a little help/guidance on where to go from here?
Thanks in advance
Old 05-09-2014, 06:06 PM
tseekins's Avatar
tseekins tseekins is offline
tseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputation
Welcome to FTE!
I'll move this to the correct forum so you can get maximum exposure.
Old 05-09-2014, 11:10 PM
VTX1800N1 VTX1800N1 is offline
VTX1800N1 is starting off with a positive reputation.
95 5.8L Crank But No Start Previous KOER flash Code 34 Tim Hodgson 1987 - 1996 F150 & Larger F-Series Trucks 45 10-05-2015 10:25 AM
front driveshaft info NMFirstF2504X4 1973 - 1979 F-100 & Larger F-Series Trucks 4 07-14-2015 07:40 AM
Dual Battery Disconnect bismic 6.0L Power Stroke Diesel 8 04-09-2015 12:47 AM
7HT problems 230thdratsab 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 09-15-2013 07:05 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
