Lift is being installed today...
I got the bully universal ones. I'm always skeptical about anything that says "universal fit" but they worked perfectly. They use a screw on the top holes into the body, and a bolt through the step and pinch weld strip - I'm pushing 250lbs and they hold me just fine.
Robot Check
Robot Check
After having this lift on for some time now, I'm still loving it and will never return it to it's former OEM height.
On another note, I've noticed that with extremely sharp turning, I was getting some light rubbing as seen here...
So, I decided to throw on a set of Bora 2" hub-centric & wheel-centric spacers to resolve the problem...which it did. However, now I have rubbing on the rear of the front fenders here...
Just can't seem to win here. I'm thinking about either switching to a 1" set of spacers or somehow bending the rear of the fender well a bit to accommodate the new turn radius.
Suggestions?
Thanx.
Suggestions?
Thanx.
