Lift is being installed today... - Page 2 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 05-12-2014, 10:50 PM
jswartz84's Avatar
jswartz84 jswartz84 is offline
jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.
Quote:
Originally Posted by dmallen View Post
Here's a better comparison...
Looks good.
Old 05-14-2014, 01:24 PM
dmallen's Avatar
dmallen dmallen is offline
dmallen is starting off with a positive reputation.
Quote:
Originally Posted by WickidPissa View Post
I got the bully universal ones. I'm always skeptical about anything that says "universal fit" but they worked perfectly. They use a screw on the top holes into the body, and a bolt through the step and pinch weld strip - I'm pushing 250lbs and they hold me just fine.
Robot Check
I was looking at the AMP PowerStep product and even though it seems to have the lowest drop available (outside of a custom-manufactured product), it still only drops about 2-inches lower than my OEM step bars. Yes, I can go with the extensions, which will give me an additional 3-inches, but then the step bar would be visible and I'm trying to go for the "hidden" look. Does anyone know of any other powered-retractable product out there that would drop lower (short of telling the wife to bring her stepladder with her )? Thanx again.
Old 05-15-2014, 12:12 PM
Eatonpcat's Avatar
Eatonpcat Eatonpcat is offline
Eatonpcat has a great reputation on FTE.Eatonpcat has a great reputation on FTE.Eatonpcat has a great reputation on FTE.Eatonpcat has a great reputation on FTE.
LOOKS GREAT!
Old 05-16-2014, 09:42 AM
SuperDutyScaler's Avatar
SuperDutyScaler SuperDutyScaler is offline
SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.
you cab barely notice that change LOL just kidding truck looks awesome! One question though... how did you get a 8" lift and keep the stock rear springs and top overload?? A massive rear lift block.......
Old 05-16-2014, 10:55 AM
dmallen's Avatar
Yup...
Before I did this, I'd never seen a u-bolt so long!
Old 05-16-2014, 11:18 AM
WickidPissa's Avatar
WickidPissa WickidPissa is offline
Important Businessman
WickidPissa has a great reputation on FTE.WickidPissa has a great reputation on FTE.WickidPissa has a great reputation on FTE.WickidPissa has a great reputation on FTE.
That's exactly what I did - went with the blocks for now. I figure later on I can upgrade the rear springs.
Old 08-07-2015, 10:27 AM
dmallen's Avatar
After having this lift on for some time now, I'm still loving it and will never return it to it's former OEM height.
On another note, I've noticed that with extremely sharp turning, I was getting some light rubbing as seen here...
So, I decided to throw on a set of Bora 2" hub-centric & wheel-centric spacers to resolve the problem...which it did. However, now I have rubbing on the rear of the front fenders here...
Just can't seem to win here. I'm thinking about either switching to a 1" set of spacers or somehow bending the rear of the fender well a bit to accommodate the new turn radius.
Suggestions?
Thanx.
Old 08-07-2015, 11:52 AM
Long Haul's Avatar
Long Haul Long Haul is online now
Long Haul has a great reputation on FTE.Long Haul has a great reputation on FTE.Long Haul has a great reputation on FTE.Long Haul has a great reputation on FTE.Long Haul has a great reputation on FTE.
Truck looks really good nice job..
Old 08-07-2015, 03:38 PM
evan1242's Avatar
evan1242 evan1242 is offline
evan1242 has a very good reputation on FTE.evan1242 has a very good reputation on FTE.evan1242 has a very good reputation on FTE.
good choices on lift and tires sir!
looks very good.
What everyone's thoughts on Lifted 2wd F100s casey88307 1967 - 1972 F-100 & Larger F-Series Trucks 4 02-09-2016 10:49 PM
lift kit jamesds016 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 01-29-2016 08:51 PM
OEM Jack for lifted truck IronCobra 6.7L Power Stroke Diesel 2 06-29-2015 12:41 PM
Grabbing just a little more lift Laxbrosam 1999 to 2016 Super Duty 1 04-02-2015 09:25 PM
Lift Kit Edds 1978 - 1996 Big Bronco 18 03-16-2015 11:29 AM
Tags
fabtech, fuel, lift, tires, toyo, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
