what controls vacume to the heater control valve????
hi everybody
I am working on a 97 exporer with the 5.0
If you manualy manipulate the heater control valve the air tempeture will change, but the valve will not move when using the switch.
I checked for vacume at the valve and there is a constant vacume regardless of switch position.
where do i look next, what controls the vacume that controls the heater control valve?
Thanks for the help guys.
Does your Explorer have the manual (****) HVAC controls or electronic climate controls? I don't recall if both use a vacuum controlled heater control valve. The valve is controlled by the climate control control unit via vacuum lines and a vacuum reservoir. I'm struggling to find the vacuum diagram currently in the service manual to determine if vacuum opens or closes the valve.
-Rod
-Rod
Seth Matthews
12-23-2018 03:20 PM
Torquin
12-15-2015 05:22 AM
fordx94
12-23-2004 09:55 PM
