New owner here having a ticking issue I narrowed it down. - Ford Truck Enthusiasts Forums
Old 05-09-2014, 01:27 AM
Alex Rodriguez's Avatar
Alex Rodriguez Alex Rodriguez is offline
Alex Rodriguez is starting off with a positive reputation.
I just purchased my 2006 F250 5.4 gas and absolutely love it. Everything works great no issues. My only concern is this ticking noise.
I searched the forum but it doesn't sound like the infamous cam issue or injector ticking. I even search YouTube videos and doesn't sound like those either. The noise is not coming from the front cam area.
Today just looking through the bay while the vehicle is running touched cylinder 5 coil then touched cylinder 6 and found the Ticking!!!!!!!!
Cylinder 6 coil is ticking. I haven't checked it since I just got home could a lose sparkplug or coil make the ticking noise. If the coil was bad it would misfire and I would get a CEL but I don't. And she drives great.
Any input would be greatly appreciated
Old 05-09-2014, 07:46 PM
je5 je5 is offline
je5 is starting off with a positive reputation.
Do not start the engine again before removing the sparkplugs and inspecting the plug hole threads and replacing the plugs with anti-seize and proper torque. You may save some broken coils by catching this early. Read about tune-up on your model to see if you want to do the work. The HT sparkplugs are problematic on your model and it sounds like some are already broken and leaking compression. Someone may have tried removal already.
Old 05-09-2014, 08:09 PM
Ok got home today
After removing the coil the spark plug was hand tight! I literally put my 9/16 with a extension and as I spin the socket to slip over I actually felt it spin and I didnt even use the ratchet. So I cleaned the plug good inspect the end all was good put abti seize on the end and threads.
Fired her up and absolutely no ticking or weird noises.
Problem solved.
Old 05-10-2014, 02:00 AM
je5 je5 is offline
Glad you fixed it, welcome to FTE.
Old 05-10-2014, 01:03 PM
Thanks brother
Funny thing is I had asked a local ford dealer about the issue and he quickly searching here m phaser. Its going to be $160 for us to look into it then what ever the issue is charge you for that and parts.
I told him
Sir I build my own motors I just need your advice not a chance for me to break my bank. after searching here for 5 mins a narrowed it down. Dont get me wrong the common cam phaser noises and a loose spark plug sound almost identical.
Old 05-10-2014, 05:05 PM
je5 je5 is offline
Yes, minimum oil pressure has a lot to do with the cam timing and phaser. Take care.
Ticking noise Superdutystiller 1999 to 2016 Super Duty 3 05-07-2015 02:51 PM
new to me 2011 3.5 eco 2011 f150 ticking noise, anybody? Truckie256 EcoBoost (all engine sizes) 4 12-16-2014 07:56 PM
Lifter has a flat...Pumping it up? SCWIDVICIOUS 1961 - 1966 F-100 & Larger F-Series Trucks 14 06-30-2006 06:44 PM
Anyone's truck make a ticking noise? Yogi-96blazer Ford Inline Six, 200, 250, 4.9L / 300 20 02-25-2006 07:53 AM
ticking that doesn't increase with rpms deserttruck Modular V8 (4.6L, 5.4L) 6 12-30-2004 04:36 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
