Injector line. - Ford Truck Enthusiasts Forums
Injector line.
Old 05-09-2014, 01:19 AM
rwelli1001 rwelli1001 is offline
rwelli1001 is starting off with a positive reputation.
Injector line.
Holy cow. Had my Injector pump off for return line fittings and O-ring replacements. When I was cleaning up the pump and injector lines I noticed some wear on the steel line for cylinder # 8. A hole almost rubbed half way thru the steel line. Source of problem was the Cruise control cable was routed over and laying on the steel line. Over time the ribbed cable sheath had acted like a saw and was cutting the line in two. (Not leaking yet.)
I rerouted the cable to go under the injector line.
Local International dealer can get me the one new steel line for about $140.00. and wait time.
Hydraulic shop across the street from the dealer can make me one for about $60.00 when I take the bad one in for a pattern to follow. Same day service.
Posting this for others to check on their rigs before they have same problem.
Old 08-28-2014, 11:13 PM
Ended up buying a new line. Hydraulic shop was not able to duplicate the flared ends and I did not want to risk a weld repair.
Old 08-28-2014, 11:27 PM
sjwelds's Avatar
sjwelds sjwelds is online now
sjwelds is starting off with a positive reputation.
I weld hydraulic lines that see upwards of 2500 psi frequently. So far don't know of any problems.
JM2CW
Old 08-30-2014, 12:02 AM
Sycostang67's Avatar
Sycostang67 Sycostang67 is offline
Sycostang67 has a very good reputation on FTE.Sycostang67 has a very good reputation on FTE.Sycostang67 has a very good reputation on FTE.
Did you check salvage yards? I scored a complete set of lines for $11. They came in handy when I had my 86 as the PO had cross threaded the #8 line and ruined the injector threads and the flare on the line.
New IP & Injectors!! + Fuel Leak jmuenchow Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 03-02-2015 11:57 PM
NiCopp brake line flaring problems granny_rocket Brakes, Steering, Suspension, Tires, & Wheels 4 11-15-2014 06:42 AM
MODS **idi Turbo** Breaker Breaker 3-3 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 03-21-2012 03:32 AM
priming a 6.9 injection pump mudkicker715 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 18 05-18-2009 10:33 PM
1998 Explorer Fuel Line Repair or Replace? petdoc87 Explorer, Sport Trac, Mountaineer & Aviator 3 09-13-2007 06:27 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
