Won't rev pas 2k ish, new injectors, good fuel pressure, no boost, turbo soot pics! - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 05-08-2014, 11:26 PM
lemonshindig lemonshindig is offline
lemonshindig is starting off with a positive reputation.
My truck has brand spankin' new (rebuilt) stage-1 injectors from Rosewood. It still smokes like a bandit and hangs around 2k. It doesn't have a lot of power. Only every once in a while will it accelerate smoothly.
I have a gauge on the passenger side high-pressure oil line. It's reading around 700 at idle, and comes up to 1800-2k at WOT. When the revving hangs up, so does the gauge, and then after a moment, if it feels like it, the RPMs climb and the pressure climbs by a couple hundred PSI at the same time.
I'm fairly certain this is a high-pressure oil problem. I tried to measure the duty cycle of the IPR with a multimeter and got really strange numbers. 80% at idle, and around 50% at WOT. Weird.
Now I'm thinking I can start the truck and momentarily apply 12V 100% DC to the red/yellow wire to the IPR and the pressure should climb. If not... IPR is my guess. But it could be the HPOP. And I suppose I'd have to pressure test each head.
Old 05-08-2014, 11:44 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is online now
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
I think your on the right track. It might also be the ICP, try unplugging it and drive it to see if that makes a difference.
Old 05-08-2014, 11:49 PM
Unplugging the ICP doesn't make a noticeable difference in performance. I did try that, I drove about 8 highway miles unplugged, and plugged it back in. It still performed poorly in both situations.
Being as the truck can actually maintain highway speeds now, I have been driving it. It's probably seen 80 miles since the injectors were put in, so I think all the air should be purged.
Thanks
-Matt
Old 05-09-2014, 12:06 AM
I jumped the yellow/red wire to + with the engine running and the IPR would open up and the pressure would drop. I then jumped it to the - post and it would skyrocket, one of my quick jumps hit like 3300psi. This would lead me to believe that the IPR and HPOP are capable of producing the pressures needed. It would also lead me to believe that maybe I didn't have my meter set correctly, because apparently the duty cycle to the IPR is controlled by switching the ground on and off, not the 12V line.
ICP unplugged doesn't improve driveability much. It still hangs somewhere between 2k and 2500.
So, unless the default ICP tables are EXTREMELY conservative and prevent the truck from reving, the only likely culprit at this point is low boost or the MAP sensor. So tomorrow I'm going to throw a boost gauge in. Is there a boost pressure to MAP voltage table floating around for testing?
Old 05-09-2014, 12:26 AM
So I unplugged the MAP sensor and took it for a drive. The truck seems to respond well for the most part. But once on the highway in 4th gear, it still hit a hang-up wall around 2500. At the wall, there was a lot of room left on the pedal which didn't do anything to bring up the RPMs, however there was a definite increase in turbo noise if I stepped on it further. To me, this would suggest that the turbo is definitely increasing in boost, but the truck isn't responding with the appropriate pressure. Granted, this may have been isolated to this drive just because the MAP was unplugged.
Old 05-09-2014, 12:51 PM
cowmilker08's Avatar
cowmilker08 cowmilker08 is offline
cowmilker08 has a good reputation on FTE.cowmilker08 has a good reputation on FTE.cowmilker08 has a good reputation on FTE.
It sounds like you did good checking the HPO system.
You should be able to rev the engine over 3000 rpms easily. A stock truck should be programmed to produce a maximum of 2600ish psi on the HPO, IIRC.
Have you checked the fuel side of things?
Also, 80 miles is probably not enough to get all the air out of the system.
Old 05-09-2014, 04:14 PM
strokin'_tatsch's Avatar
strokin'_tatsch strokin'_tatsch is offline
strokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud of
Unplugging the ICP sensor should make a difference. You should hear a change in the idle when you unplug it while running. If you do not hear this change, it might not be a bad idea to try a new ICP sensor. Is there any oil inside the ICP sensor where the electrical connector plugs into it?
It's important to remember also that stage 1's will run just like a stock injector without aftermarket tuning. So if you don't have a chip in the truck, don't expect any extra power over stock from it.
Just for grins, check your oil level and open the fuel bowl to see if there is any oil in the fuel. I've had messed up injector o-rings cause a hang up in the upper RPMs before. Improper installation can result in damaged o-rings.
Old 05-10-2014, 10:23 PM
dougbrown's Avatar
dougbrown dougbrown is offline
dougbrown has a very good reputation on FTE.dougbrown has a very good reputation on FTE.dougbrown has a very good reputation on FTE.
Not to high jack this thread but I'm thinking I got a Hpop problem. Where did you guys get your gauges for testing?
Old 05-10-2014, 11:44 PM
Old 05-11-2014, 12:22 AM
21411 21411 is offline
21411 is starting off with a positive reputation.
Doug ~$70 for the hose, tee fitting and 5000psi gauge at my local parker store (catching fluid power)
OP - you have the fuel bowl and mechanical pump? mine had similar sounding issues, that turned out to be a bad pump. did a DIY on the fly e fuel. runs way better now that it's all sorted out.
Old 05-11-2014, 12:35 AM
dougbrown's Avatar
You don't happen to have a part number
Old 05-11-2014, 07:35 AM
DZL JIM's Avatar
DZL JIM DZL JIM is offline
PREMIUM SPONSOR
DZL JIM has a great reputation on FTE.DZL JIM has a great reputation on FTE.DZL JIM has a great reputation on FTE.DZL JIM has a great reputation on FTE.DZL JIM has a great reputation on FTE.DZL JIM has a great reputation on FTE.
If you unplugged the MAP sensor and it ran better, there's something wrong there. If/when the MAP is unplugged, the truck should be a total TURD.
Unless I missed something.
Also, like Travis said, you should notice significant change in idle or something when the ICP sensor is unplugged. A scanner will read 0 volts and 724 psi, or something, but even by ear you will notice a change.
We can do a pretty good job pinpointing oil pressure issues in the injectors, but that's not to say there isn't a problem there. If you eliminate everything else I can explain how to do a test for the High Pressure Oil side. But it really doesn't sound like that's your problem yet.
__________________
'96 F-350 Reg Cab 4x4 PSD
'05 F-250 6.0 cc 4x4
DZLJIM.com
Old 05-11-2014, 08:00 AM
Pikachu's Avatar
Pikachu Pikachu is offline
Pikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud of
Quote:
The MAP sensor uses a frequency signal rather than voltage on the OBS trucks.
At 14.7 psi (standard barometric pressure at sea level), it should be 111 hz. I don't know if AE will read that parameter or not, but in case it does, here are some values for you:
Code:
Hz        PSI
94        10
102       12
109       14
111       14.7
116       16
123       18
I'm pretty sure the PCM will use an inferred MAP value if you disconnect the wiring harness from the MAP sensor, but not if the hose is simply disconnected. Have you checked the hose for leaks/cracks?
EDIT: Just noticed the title actually says "without AE", but there you have it anyhow, lol.
Old 05-12-2014, 12:45 PM
If you have an Android smartphone or tablet you can by this $5 dollar app that works a lot like AE, but more limited. Its called Torque Pro. It will show you ICP pressure and IPR DC like AE does. You also have to have an OBDII-to-Bluetooth adapter (maybe a wired adapter would work too?), which costs about $12. Look these threads over for the details:
SD thread: http://www.ford-trucks.com/forums/12...-in-bacon.html
OBS thread: http://www.ford-trucks.com/forums/12...werstroke.html
Old 05-13-2014, 07:50 PM
I drove 350 miles with no power. I was topped out at 45mph going up some of the mountain inclines.
Then I installed a boost gauge and made the return trip. It never went over 5psi. Once I hit the power wall, if I pushed the pedal down past it, I could hear the noise of the exhaust or turbo change to a higher pitch, but the gauge wouldn't really move, and the truck wouldn't rev higher.
So now I suspect a boost or up pipe leak.
6.0L - Difference between model years bismic 6.0L Power Stroke Diesel 34 12-29-2016 12:18 AM
IPR class Tugly 1999 - 2003 7.3L Power Stroke Diesel 1 09-20-2015 10:00 PM
HPOP testing or oil rail leaks kurboman 6.0L Power Stroke Diesel 1 10-08-2014 07:10 PM
AE or spare IDM in Seattle? I'll buy dinner and beer. lemonshindig 1994.5 - 1997 7.3L Power Stroke Diesel 1 06-14-2014 11:11 PM
1995 OBS 1211 code on hard acceleration txoutlaw1 1994.5 - 1997 7.3L Power Stroke Diesel 6 01-07-2013 01:05 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
